I moved this from another post so I didnt hyjack it! ![Face Icon Small Wink :face-icon-small-win :face-icon-small-win](https://www.snowest.com/forum/images/smilies/old/face-icon-small-wink.gif)
The Chassis Power Capacitor, a 28000uF capacitor is mounted next to the ECU in front of the fuel tank tank on the 2005 -2006 Cfi's. (it is riveted to the bracket) and is located on the beltguard, under the cover mounted to the regualtor on the 2007 - 2009 RMK's. #3 in the pic at the bottom. can have problems and cause fuel pressure fluctions as well as ECU issues that are related to power. Part # is 4011114 and was used on all CFI sleds from 2005 thru present.
I've also had a bad chassis power-up relay cause starting problems... stuck in the closed positon that caused problems. This allowed the little bit of power that was produced by the stator to bleed off thru the headlights and not allow it to start.
On all CFI sleds, remove the nut to the ground wire on the chasis each season clean the ring terminals with a scotch brite pad as well as the stud/chassis location and put re-install using electrial grease (commonly sold on the lightbulb section of your autoparts store). The Ground point on the chassis is crucial for proper operation of the engine.
Also, on All the CFI sleds, you should keep a spare chassis power relay zip tied under the hood in case that goes on you... Plus, if you ride with Doo guys, you'll be the hero when the lights and gauges stop working on thier sleds.
The symptoms of a bad chassis power relay are lights,handwarmer, instrument etc not working at all or flickering.
You can get a better than Polaris quality relay at Napa for about $15....Napa part # AR274
Location of Chassis Power Capicitor on 2005-2006 900/700 CFI sleds
ling:Dropped it off at the dealer after the trip and it has been at the dealership basically for the last 4 months trying to solve this bogging issues (under warranty). I get a call that they got the bog fixed (capacitor problem)
donbrown: For my own knowledge what capacitor did they have to replace? Do you have a part number and location?
Chassis Relay: The chassis relay is activated by the
ECU at approximately 950 RPM. Below 950 RPM (700 rpm on the 900 cfi's), all
power supplied by the regulator / rectifier (RED circuit)
is used to power the ECU and fuel pump.
CAPACITOR: The function of the capacitor is to act like a battery in a non-battery system. The capacitor makes the chassis side power signal stable. WIth out the capacitor in the system the unit will not run correctly. The capacitor suppresses voltage spikes and ensures consistent voltage throughout the chassis (RED/WHT) circuit.
Capacitor Testing
1. Charge the capacitor for 10 seconds using a 12 volt battery
by connecting the positive (+) lead to the Red/White wire
and the negative (-) lead to the brown wire.
2. Monitor the capacitor voltage with a multimeter. The
voltage should slowly drain down from the initial charge.
If the cap does not hold a charge or drains rapidly, replace
the component.
![Relayandground.jpg](http://i112.photobucket.com/albums/n189/androgenei/Relayandground.jpg)
For the 2007 - 2009 CFI's
ECU at approximately 950 RPM. Below 950 RPM, all
• Regulator / Rectifier: Responsible for converting Vac to Vdc for the chassis and battery (electric start) circuits.
Regulates voltage to 14.5 Vdc. Also supplies fuel injector “boost” power when engine RPM is 700 RPM or less.
![Capacitorlocation.jpg](http://i112.photobucket.com/albums/n189/androgenei/Capacitorlocation.jpg)
![08800RMK.gif](http://parts.polarisind.com/images/SNOW/CLUTCHGUARD/08800RMK.gif)
