big wheel kit
E
extremsledder
New member
2
18
32
quesnel b.c.
soi just bought a big wheel kit and now iam thinking right now iam running a 144 and i bought the wheel kit with the intention of takeing up the slack in the track because iam almost out of track adjustment now iam wondering if i can run a 151 with the big wheel kit or if it will not take up anuf of the track lenght but i also have a set of slp rail exstentions to go from 144-151 but i dont know if i can run my wheel kit with the extensions because where the axel go's throught the exstention i think it might be widr than that spot on the rail so ya any info would be help full and also i dony know what make the wheel kit is because i bought it used aqnd it didnt say
A
37
Rapid City, SD
If the wheel kit came with the propper offset axel kit than you would be able to run the 151" track with the bigwheel kit and rail extesions. Could you post some pictures so we can see the situation a little better
R
1
18
COSTCO
i dont think youll have enough adjustment to take up 7 inches of slacl in youre track with just the axle . i went from a 153 to a 156 with a new axle and bigger wheels and it worked out awsome. mabey try new rails there the same price as rail extensions and an off set axle and you can get then cut to run what ever size wheels / track you want
E
extremsledder
New member
2
18
32
quesnel b.c.
um man its only 4 inches to go from 144 to 151 and the wheel kit takes up 3 inches of theat and with extroverts i can run my track really lose so i think it will work
E
extremsledder
New member
2
18
32
quesnel b.c.
and actilly its only 3.5 inches to go from 144-151 because if you go 144-151=7divided by 2 =3.5 just like 144-136=8divided by 2 =4 so iam only .5 of a inch short with my wheel kit
G
Gone Sleddin
25
when they say 3 inches, they mean 3 inches of track ie. 156-159. the offset axle and bigwheels will not be enough to take up the slack from a 144-151 without a skid relocation or using extensions
E
extremsledder
New member
2
18
32
quesnel b.c.
ok guys this is what it says on there site
Offset axle kits for long tracks can be turned around for a
3” extension so you need 3.5" extensin for 144 to151 o why wont it work?
Rixster
3,781
651
Springville, UT
I used 9 inch wheels to go from a 159 to a 162. It BEARLY worked, I am completey out of adjustment. If my track stretches any more I am not going to be in good shape.
