Yamaha shock blow-out - FOX, Elka, Ohlins, Works, & KYB
Mountain Performance is blowing out inventory.
All sales final- no returns. All parts on this listing are brand new and have never been used.
To order please call
801-619-1569
WORKS
All Works Shocks feature dual rate springs with adjustable coupling and preload. All shocks also feature high pressure gas and can be rebuilt and revalved. Ski shocks are sold in pairs and are available in two styles: clevis mount and eye mount. 38” and 42” models use clevis mounts. The rear shock is available in 3 models, Gasser, Dura and Ultra. Duras and Ultras are large body shocks and the Ultra also has adjustable damping. All models can be fitted with an optional remote adjustable reservoir
aaw-0730 Works 97-03 12" Center RX-1 $225 was $299
aaw-0605 Works 97-03 12" Rear Gasser RX-1 $225 was $299
aaw-0625 Works 97-03 12" Rear Ultra Adjustable Large Body RX-1 $499 was $799
ELKA
Elka is the best shock money can buy. It has all the features of the Ohlins plus some. Triple Rate springs, Zero Preload, Adjustable Rebound & Compression, Billet Aluminum Construction. The Best Performance, the best ride, the best durability of any snowmobile shock. Ski Shocks utilize an inverted design with the body of the shock mounting to the bulkhead and the shaft mounting to the ski. This reduces sprung weight and results in an improved ride.
aae-0600 RX-1 Mountain Rear Suspension Pair
(center adj compression; rear adj comp & rebound) $750 Was $999
OHLINS
Top notch Performance, the great ride, the awesome durability. Ski Shocks utilize an inverted design with the body of the shock mounting to the bulkhead and the shaft mounting to the ski. This reduces sprung weight and results in an improved ride.
aao-0351 Öhlins 12" Center RX-1 (36mm Internal Reservior) $249.95 was $349
FOX FLOATS
see image below
aaf-0100 Apex Mountain, RX-1 Mountain & Vector Mountain Front Ski Shock Kit Special $599
KYB
Aluminum Kayaba OEM Yamaha shocks are far superior to the factory steel stock shocks. They provide excellent heat dissipation, run much cooler & reduce fading. Shocks feature a floating piston, nitrogen pressurized design & are completely rebuildable & revalveable.
aas-2700 KYB Center Shocks All 11.5" Travel $150 was $309.76
aas-2600 KYB Rear Shocks All 11.5" Travel $150 was $335.32
TITANIUM SPRINGS
Titanium springs are designed to fit any 97-02 Yamaha with 11.5" rear travel (KYB, Öhlins or Fox). Titanium offers several advantages over conventional rear springs with: Significant Weight Reduction, Superior Ride Quality, & No Rust. The rear set saves 4.6lbs.
ast-0130 Front Ski Spring 2.3 kg/mm (each) $99.95 was $160.00
ast-0140 Front Ski Spring 2.5 kg/mm (each) $99.95 was $160.00
ast-0100 Titanium Springs - Center & Rear Pair All 2 shock models $399.95 was $549.95
SHOCK SKINS
Save Weight, save your shock shafts from costly ice damage, and look cool! These covers do it all. They are available for most common shock absorbers. If your shock is not listed, call. They are made with a large thread diameter in the core material which is much more abrasion resistant, adding durability and extending the shock cover’s life without sacrificing fit. They are also made with Denier nylon (an extremely strong, water repellent material) which will not tear or develop holes. Perfect fit every time!
acc-2500 Long Travel Front Shocks - All Models (pair) $15 was $30
acc-0500 Short Travel Front Shocks - All Models (pair) $15 was $30
acc-0700 Rear and Center All Models (pair) $20 was $35
801-619-1569
WORKS
ELKA
OHLINS
FOX FLOATS
see image below
KYB
TITANIUM SPRINGS
SHOCK SKINS
