T
Togwotee Madness
New member
Hey I have a 2008 M1000 SnoPro.
Since the day I picked it up it has had a bottom end bog around 39-4100 RPM and sometimes when you let it idle it will just stall. This only happens when the sled is fully warmed up and only below 4100RPM or so. It runs strong above that.
I have had it to the dealer twice now (it is in for the 3rd time presently) and the dealer keeps giving me a whole bunch of Double Speak. ie you used the wrong gas, it is snow calving, it is the throttle switch etc etc. well I am running 87 octane as per the manual and have tried isopropyl or no isopropyl and the problem is still there. The second time the dealer changed the Fuel Pump and regulator assembly an the associated smart valves in the fuel tank. No Luck
I am wondering if this is and ECU problem as it happens before clutch engage RPM and if anyone has any advice. I have lost faith in my dealer at this point.
NOTE
there are no ECU codes or any other abnormal indications
The sled works fine when you first start riding.
Thanks in Advance
NOTE
Thanks in Advance
