D
who's seen one run ? Is it worth the trouble... hp#s Hows it compare to a well running 900. Lets here it boyz whats the skinny? Hello anyone????
.060 sounds right, if you use Cat's gaskets. Oh yeah, we had to regrind the exhaust valves to match the larger bore too. They're not working. That's giving me fits right now. It could be that the travel of the valves are less and the servo goes to default. Although I seem to be having a voltage problem too, maybe they're related.
Owen
I wouldn't want to remove the valves completely. They are designed in for a reason, they make the engine more efficient at lower RPM so you get better low speed operation, as well as fuel economy. I know lots of people get rid of them, so this is more personal preference. If you do block them open, do you have to plug something into the ecu to trick it? Or do you just unplug the servo?
If it's efi you need a by pass chip or it goes in to limp mode.
