Question for the masses, are driveshafts interchangeable between the 11-15 Pro and the 16-17 Axys.
Specically, could I take a 14 Assualt driveshaft (with correct pitch & tooth drivers) and swap it onto my 16 Axys RMK?
Yes you can put the pro steal drive shaft into the axys quickdrive, you can also run 8 tooth 2.86p drivers with the 2.6" track with plenty of clearance but you will then need to buy a gear down kit with the 8 tooth drivers.
unless you are boosted
Yep- and beleive me the swap helps!!
True, but that will give you a final ratio of 1.95, thats a pretty tall order, lol
I know the aluminium hex shafts will transfer. Only difference being one uses nuts and studs and the other uses bolts on the clutch side. Now the assault should be a chain case sled so i dont know if the steel driveshaft from the chaincase sled will fit the quickdrive pro rmk
Sent from my SM-G930V using Tapatalk
Yes, the drive shaft from a chain case equipped sled (Pro-Ride or Axys) will fit in a sled with the Quick Drive system, but you can NOT run a QD specific drive shaft in a chain case equipped sled (no flange for the oil seal). I currently have a drive shaft for the '16 chain case equipped Axys sleds on my Quick Drive Axys Pro-RMK.
I tried to install a pro rmk steel driveshaft 8tooth 2.86 on my SKS but with the 8 tooth sprocket the track was way too tight.
But the driveshaft is bolt on
I Will run a Silber kit on a 163" could you tell us more?
Envoyé de mon iPhone en utilisant Tapatalk
If you use any drive shaft other than the Axys Pro-RMK drive shaft, you will need to use the shorter lower bolt from the 15 QD lower sprocket.
Whats the PN to this?
