octane is not the only thing to look at when considering fuel, the av gas has many great qualities {good octane, led for lube great shelf life and over all good for our needs in boosted sleds. is it the best naaaaa far from it but for the price probably hard to beat !!! like I stated above what does it do {pulse?}
||About 801||
The overwhelming need to win is a primal urge pumping through the DNA of racers everywhere. It’s triggered the nanosecond after your first victory and doesn’t stop until the nanosecond after your last breath. Once you’ve tasted it you’re ruined for life. You’ll do whatever it takes to chase and catch that feeling again. Racers are constantly altering, transforming, revolutionizing, inventing and innovating whatever they can to subtract precious time off the clock. Ingenuity is the name of the game, and whoever plays the game the best, wins.
801 Racing exists to help you do just that. We are racing die-hards with deep roots in the fuel additive industry. We’ve spent countless hours in the lab and at the track over the last decade developing cutting edge products that make sure you get your winning fix. Simply put, we make things that make you go faster. We are 801 Racing and we’ve got exactly what you’re looking for. Gentlemen, start your engines.
about us
801 Racing is a group of racing die-hards from Orem, Utah with deep roots in the fuel additive industry. They’ve spent countless hours in the lab and at the track over the last decade developing cutting edge products that make sure you get your winning fix. They currently offer PULSE, a power boost fuel additive that provides an immediate measurable increase in horsepower in diesel, gasoline and methanol powered internal combustion engines.
We Won't Stop Until You're Faster !!!
Solid Fuel Technology - " PULSE POWER BOOST "
801 Racing produces a unique and innovative product named Pulse Power Boost, it comes in a solid red ball and is a fuel boost catalyst that completely dissolves in the fuel tank. PULSE provides an immediate measurable increase in horsepower in gasoline, diesel and methanol powered engines. PULSE has consistently demonstrated increased overall performance, providing smoother cold starts, increased throttle response and less knock under load. In addition to increased power and performance, PULSE works to remove hard carbon deposits and reduce engine maintenance costs. Pulse Power Boost will come packaged in a sealed pouch (2 pack) or in an embossed display tin. (6 pack)
One of the most frequently asked technical questions we get at VP involves the difference between Motor, Research and R+M/2 Octane Numbers. The next most frequently asked question is why some fuel companies represent their fuels with Motor Octane Numbers, while other companies use Research or R+M/2 Octane Numbers.
Realize first that octane is a measurement of a fuel’s ability to resist detonation—nothing more. The two types of machines used for testing octane—a Motor Octane machine and a Research Octane machine—were designed in the 1930s. They were designed to test for octane numbers from the 0-100 range, therefore, any number above 100 is an extrapolation.
Both of these machines are dinosaurs and are not adequate for today's high tech fuels or engines, but they’re the only means available for testing fuels. These machines are one-cylinder engines with an adjustable head that can move up or down to increase or lower the compression ratio while the engine is running. The Motor and Research machines are the same in this respect, but they differ in several other characteristics.
The following is a comparison of the two machines used for testing octane numbers:
---------------------- Motor Octane Machine --------- Research Octane Machine
RPM --------------------------900------------------------------ 600
INTAKE TEMP.---------------300 DEGREES F -----------------120 DEGREES F
TIMING --------------------VARIABLE BASIC------------------FIXED AT 13 DEGREES
(DOES NOT CHANGE)
----------------------------SETTING 26 DEGREES
As you can see, the Motor Octane machine runs at a higher RPM, higher temperature and more timing. This machine puts more stress on the fuel than a Research machine and more accurately simulates a racing engine. VP Racing Fuels always includes Motor Octane Numbers when promoting its fuels because our fuels are used exclusively for racing applications.
The Research Octane machine will always produce a higher number for the obvious reason that it does not put the same amount of stress on the fuel. This number is used by some fuel companies to trick the racer into thinking the fuel is rated higher, i.e., higher quality, than it really is. The “R+M/2” Octane Number is the average of the Research and Motor Octane numbers for a fuel and is the number displayed with yellow labels on retail level gas pumps.
When comparing fuels for racing purposes make sure to compare Motor Octane Numbers because these are the ones that count in your racing application. Focusing on the MON of each fuel will help ensure you’re comparing apples to apples with regard to octane.
But bear in mind, a fuel’s ability to prevent detonation is a function of more than just octane. For example, VP’s fuels—oxygenated or nonoxygenated—vaporize much better than competitive fuels with comparable octane ratings. This means VP fuels cool the intake charge, burn faster and yield more efficient combustion. As a result, the “effective” octane rating of VP’s fuels is even higher than the rating generated by the octane test. As a result, VP fuels will prevent detonation more effectively than competitive fuels with comparable MONs.
__________________
so I don't know if u read part 1and 2 of this post but the octane is just one of many things to conceder when buying or modifying fuels. VPs sight is packed with info and great fuels they are just costly and not in my back yard!! so I am looking for a additive that may help the burn quality of AV gas not detonation quality , I don't know what pulse from 801 racing or madditive power boost from VP is riley doing to the fuels?? I know they "don't" raise octane (and that's good I'm not looking for that AV fuels have plenty) just looking for a better fuel for a good price that's easy for me to get.
Why would you use it? What does it do?
It don't raise the octane number at all:
"Q. Does PULSE change the octane levels of fuel?
A. PULSE does not change octane levels or any other fuel specifications."
they are not dried jellybeans lol they do something?? they say hp gains I was just wanting to know if any one knew HOW they gave the gain? just seems to reason that if it "does not change octane levels or any other fuel specifications" than it would do nothing
