Nice chart GM
Impressive smart-phone skillz!
Your chart shows, well, that with a functioning "EBC" the turbo is actually not making any more boost at altitude.... Charge-side pressures remain consistent.
I've heard/read in some presentations on this and other forums that "An EBC will increase boost at altitude to maintain power levels"...which is not accurate... you are not making more boost.
Although you are NOT making more boost at altitude with a functioning EBC, the system is spinning the turbine/compressor assembly faster in the less dense air at higher elevations to maintain charge pressures. (see the 'bucket' example above). Your typical boost gauge will however READ higher boost, but the charge pressure has not changed.
The engine 'sees' the same boost at all elevations with the EBC as it keeps the MAP-sensor pressure as consistent as the system design will allow.
Simply put if you are running "6psi" at sea level. With an altitude compensating feature. Rough numbers:
Typed on my phone .. Hopefully it lines up.
Elevation. / Atmosphere PSI. / Turbo PSI. / PSI Absolute
0ft ...... ...... 14.7 .................. 6 ............ 20.7
1000ft. ...... ...... 14.2 ...... ...... 6.5 ...... ...... 20.7
2000ft. ...... ...... 13.7 ...... ...... 7 ...... ...... 20.7
3000ft. ...... ...... 13.2 ...... ...... 7.5 ............ 20.7
4000ft. ...... ...... 12.7 ....... ...... 8 ...... ...... 20.7
5000ft. ...... ...... 12.2 ...... ...... 8.5 ............ 20.7
6000ft. ...... ...... 11.8 ...... ...... 8.9 ............ 20.7
7000ft. ...... ...... 11.3 ...... ...... 9.4 ............ 20.7
8000ft. ...... ...... 10.9 ...... ...... 9.8 ............ 20.7
9000ft. ...... ...... 10.5 ...... ...... 10.2 ............ 20.7
10000ft. ...... ...... 10.1 ...... ...... 10.6 ............ 20.7
