B
b_sandgren
Looking to go with slp stage 2 on my axys and just curious how much of a difference it makes? Anyone with reviews would be much appreciated. Thanks
Very noticeable top end power. You do loose a little bottom snap... could be from my heavier weights. Went from 64 to 68 polaris weights & changed spring to polaris blue/pink stripe.
Holding 8400 on long climb with heavy snow.
Just the weight savings alone convinced me to go for it..... but the extra power really wakes this sled up.
I've had it for around 300 miles on my Axys. It really is the package to have although I haven't had a Bikeman or other setup. The weight savings are good and it has a nice medium raspy sound. Not the obnoxious sound of some cans. The biggest problem I have had is getting the clutching spot on. This sled pulls so much more than the Pro that it has been a little trial and error. Really pulls hard on top. I've thought about the head too but only if I don't need fuel adjustment through map or controller or any av/race fuel. I'm above 10k.
what spring tensions Lbs is the blue /pink
When I put the SLP pipe on I immediately gained 150-200 RPM without any clutching changes. So it does make more power. Been very happy with the performance so far. That being said, I have a Bikeman pipe on order that will be here Monday (some of us just like to tinker) and we will see if it pulls more clutch weight than the SLP. If it does, I will have a used SLP pipe for sale.
