If you are overhauling your engine... replacing the top end or draining the coolant and replacing for some reason... or just want to maximize your cooling system performance.
Here's a "Tech Tip" for ya... a laymans presentation.
Mix your coolant at 60% coolant 40% distilled water if you have the possibility of running in very cold conditions (below -30ºF/-35ºC)... as the Polaris factory does. Don't use a 50/50 mix. More than 65% coolant and you will actually Raise the freezing temperature.
If you are running in more temperate conditions.... where you will never see above, say, -20ºF/-29ºC... then run a 50/50 mix of water and coolant... you will have a little better heat transfer from the engine to the coolant.
For those that ride when it gets warm out say above 0ºF/-17ºC... it can make some difference to run with 25% coolant & 75% distilled water mix... this will give you better heat transfer to the coolant than the 50/50 mix and still give you good corrosion resistance.
If you want max heat transfer.... You can add RedLine WaterWetter™ to 100% distilled water and still have decent corrosion resistance....but you better never see anything above freezing when you use your sled.
ALSO... It is important to use de-ionized or distilled water in your mix... it will not contain other substances that can cause issues in your cooling system.
Note: Adding WaterWetter™ to 50/50 mix does not significantly raise the heat transfer ability of the mix... something I've learned in the last few years![Face Icon Small Disgusted :face-icon-small-dis :face-icon-small-dis](https://www.snowest.com/forum/images/smilies/old/face-icon-small-disgusted.gif)
![WaterWetterGraph.jpg WaterWetterGraph.jpg](https://www.snowest.com/forum/data/attachments/216/216738-742dd648bf285945665241628299801b.jpg?hash=dC3WSL8oWU)
![freezept.gif freezept.gif](https://www.snowest.com/forum/data/attachments/216/216725-e7bc4c0be378e7a1b0bfffb041edf357.jpg?hash=57xMC-N456)
![cp.gif cp.gif](https://www.snowest.com/forum/data/attachments/216/216732-fda75d7ea57218ce4f8a171db2f70a25.jpg?hash=_addfqVyGM)
