RUNNING AN AXYS-QuickDrive™ BELT ON A 2013-15 PRO WITH A TENSIONER? FOOD FOR THOUGHT.
Since the Center to center (drive/jack shaft) is longer on a 2016 AXYS-mtn sled with QuickDrive™...
Both the 2013-15 QD belt and the 2016 AXYS-QD belt are 11mm pitch and 36mm wide.
Wondering about just running this Longer 2016 AXYS-mtn QD belt on the 2013-2014-2015 QuickDrive Equipped ProRide RMK's... using an aftermarket tensioner to allow this.
This would give you the ability to mount the lower sprocket with Loctite shaft compound on the splines... On those sleds that were unlucky to have some play in the spline fit on their sled... this would eliminate this "slop" (using a new, quality, fastener of course).
Gives the ability to not have to pull/install the pulleys with a belt change... and just leave the pulleys on.
It would also give you the ability to change the belt VERY easily in the field.
Give a little bit more belt wrap on the top pulley.
Give you the ability to set proper pre-load-tension on the belt, regardless of mfg. tolerances.
Give you the ability to use the "latest tech" 11mm pitch belts from polaris...
Not break the bank.... less cost than a complete aftermarket system.
Sure a fully CNC machined aftermarket system from TKI/C3/Kurt's may be higher quality parts than the stock pulleys... but lets leave that for another thread and keep this idea as the focus of the thread.
HMMM.
Thoughts??
The TKI tensioner is only $249.00
http://shop.tkicnc.com/Polaris-Belt-Drive-Factory-Tensioner-TKI-PTEN13.htm
PHOTO WITH THE STOCK (SHORTER) 2013-15 QD FACTORY BELT AND TKI TENSIONER.
HMMM.
Thoughts??
