Has anyone thrown the new iron on a scale yet?
Ace Freely
REALLY curious if the weight is close to the claimed weight. Soooooooo....anyone fill up the tank, topped off the oil and weighed one?
Ace
That is so Awesome, With my GGB can I will be under 400lbs. Well I probably won't be because I have an SKS. But I will be on par with a Pro.
The 155 with 2.6 track rmkpro was 431lbs with no gas(oil and coolant was full).this was posted by carls cycle, and another person weighed his 155 with 3" track and was 517lbs ready to ride,all stock
nomasittinright,
Did you ever weigh your summit with all fluids? If so what was the weight?
2015 174 T3 548.6
2015 163 T3 541.6
Both completely stock and weighed the same exact way. I must say the polaris is balanced way better as I had to have the Ski Doo front straps a lot shorter
Does the Polaris have a bigger fuel tank?If the Polaris is supposed to be 50 lbs lighter dry.It must hold more fluids than the Doo. Seems a little deceiving... (NOT bashing Polaris I have a 14 and 16 pro)
