no pics of cutting off the aluminum trim, but just drill the rivets out from the tunnel roll and hack it off right before the hood strap. then drilled a couple holes and rivet the hood strap mount to the plastic. you can see two rivets on the side here.
much better for them sidehill maneuvers and riding the old iron like buradnt.
make sure you get some running board traction on the tunnel rolls! i use little hex head screws, drill a hole about every inch down the length, zip em in and done.
