SnoWest-Forums - PRO RMK TECH LINKS
5.00 star(s)
mountainhorse
So that we don't have a bunch of "Stickies" for tech threads and information.
I'm pulling them all together here in one place which will eliminate a lot of searching and put the info within easy reach.
If you have a favorite tech Threads or parts-source threads.
These are for SNOWEST PRO-RIDE Forum threads ONLY> NO outside links and no comments.
If you have something that you want to be put up... Post it up here with:
1) Title of the Thread
2) Description of the contents of the thread
3) Link to that thread.
I will come back here from time to time and move your info into the second post here and will then delete your post... this will keep the thread clean.
Thanks for your help!!
TIPS FOR BUYING/SELLING A USED "TAKE-OFF' ELECTRIC STARTER KIT
Buying and selling factory installed starter "Kits"
http://www.snowest.com/forum/showthread.php?t=349121
FINALLY: COMPLETE, REASONABLY PRICED, "KIT" FOR LORDS ADHESIVE AND AN ALTERNATIVE
Adhesive kits to use in repair/assembly/modification of your sled
http://www.snowest.com/forum/showthread.php?t=328615
Oil Pump Adjustment
How to turn up the oil pump.
http://www.snowest.com/forum/showthread.php?t=277595
CHART FOR COMMON GEAR RATIOS, AND "AT TRACK" RATIOS FOR 7 Tooth 3" PITCH DRIVERS.
Gear and chain combos and ratios for belt drives.
http://www.snowest.com/forum/showthread.php?t=369638
INFO ON GEARING DOWN A STOCK PRO RMK WITH QUICKDRIVE USING 7 TOOTH DRIVERS
Info on gearing down 2013/14/15 PRO RMK's using only 7 tooth drivers.
http://www.snowest.com/forum/showthread.php?t=380079
TECH TIP: QUICKDRIVE BELT INSTALL PROCEDURE.
help someone avoid damaging a new QuickDrive™ belt by trying to force it on.
http://www.snowest.com/forum/showthread.php?t=332656
GREASING THE PRO RMK... DO IT OFTEN AND USE EXCELLENT QUALITY GREASE
Grease can make a big differnce in how well your suspension works.
http://www.snowest.com/forum/showthread.php?t=312674
Clutch alignment and float
How-too's on this important topic.
http://www.snowest.com/forum/showthread.php?t=331118
ERROR CODE LIST (DTC'S)
LIST OF DISPLAYED CODES FOR "CHECK ENGINE ISSUES
http://www.snowest.com/forum/showthread.php?p=3863615
COOLANT TECH TIP FOR THOSE REBUILDING OR NEW TOP END OR RUNNING IN COLD / HOT AMBIENT
General discussion of coolant mixtures and coolant performance.
http://www.snowest.com/forum/showthread.php?t=406854
