one question, I am currently in the process of swapping a 2010 600 144 2' to a 155 2.4'. I have 2 2.86" drivers but do not have the center driver like a stock 155 does. Do I need this one or can I get away with the two main drivers?
Just FYI from my experience with the stock center driver, I decided to try and remove it to see if there was any pros or cons on my old 2012 Assault. It for sure ratcheted the track MORE. I had the track at polaris spec tightness. I ended up having it to be banjo string tight and it would still ratchet on hard landings or high load scenarios...
I've had my assaults do this too and the reason is the way the front torque arm is mounted in the tunnel. With the assault having the front of the skid lowered, the suspension is keeping the track tight. Once the front track spring compresses the track will become slack. Moving the skid to the rmk position will help.
Removed mine this summer also while I was realigning the drivers. Anyone else notice the track not being centered in the bulkhead?
