I wanted to pass on a Console Venting "kit" I put together for my Pro for Under $100.00.
1. Remove Console and Hood
2. Trace or Mark where you want to mount the Holz Console Vents
3. I removed the manual/tool bag on the back side of the Clutch Guard.
4. Mount the Three Vents that come with the Kit.
5. 10-32 1 1/2" Stainless bolts Mount Fan to Bottom of Vent in front of Clutch Guard (Clutch Guard is Pre Drilled by Polaris).
6. Strip connector off SPAL fan and wire ACC connector to connect up to 2A ACC DC Pwr on Hood.
7. (Optional) Cut and Shape 6" PVC Pipe to Channel air from under Clutch Guard.
Now, before anyone says anything. It probably will not be as good as the other set up out there........ but, its cheaper and will accomplish the same thing. Once I have the sled put back together I will do a "smoke" test and see how it works.
Holz Console Vents $69.99
SPAL 4" Fan (Part #30103009) $25.00
Connector for ACC 2 AMP on Hood $1.49.
Just a thought and something I did. I am sure others have thought of this and may have done it. I just thought I would pass it on.
