For Preventative measures...On a tunnel that is NOT bent/kinked yet. I recommend the FasTrax "PRO-Tector" tunnel kit.
NOTE: if you have a 2011 PRO RMK... I highly recommend that you remove the chaincase and bond it to the bulkhead like the factory did in 2012 - 2015 sleds.
ALSO... If you already have a bent tunnel OR you have your sled torn down... the Vanamburg tunnel reinforcement kits are something that you should consider.
These kits, IMO, I would consider as "mandatory" on any kinked tunnel repair I do... in addition to the repair plates as this FTX kit ties everything together in a way that the repair plates alone do not.
http://ftxmotorsports.com/index.php?cID=120&ccm_paging_p_b904=4
I have this on my sled and have installed it on others for the same reason...Preventative measures
Although I had my sled torn down before the install... FTX includes everything you need with good instructions to install it easily without tearing down your sled.
From a previous post below.
If your sled is already damaged... I Highly recommend the Vanamburg tunnel brace set... Cut from CrMo steel... very nice fit... but requires some disassembly of the sled. VE makes nice stuff.
.I'm running the FastTrax Tunnel PROtector kit on my current sled and will be installing it on my next one as well.
Install it on a new sled.. before you buckle your tunnel
IMO... It should be one of the first upgrades on your PRO RMK for anyone that crashes or hits stumps/rocks with their pro chassis RMK's...high quality laser cut stainless steel parts.. even has the long drill bit you'll need..
You don't have to disassemble the sled to install it.
Before anyone busts my chops ... YES, I paid for it.
When I first had it in my hands, I was pretty sceptical about it. I had a chassis torn down to nothing to do some other work and I installed the kit so I was able to actually feel the before and after... Before that whole area was flimsy... the FTX kit locked everything together and sandwiched the tunnel in that weak area... worth the money IMO.
