Has anybody ever blown up a boosted Phazer?
cacsrx1
752
408
Highmore SD
Going from memory and not personal experience there was several gernaded Phazers 5+ years ago.
B
BigFish BC
3,348
1,139
kitimat b.c
i cant say if they were set up proper but i have seen allot more phazer motor go than nytro or rx-apex motors.at least 2or3 to one,they just dont take boost as well.
Y
yamahajohnson220
222
128
Mine runs strong with 13lbs, no headshim, 100LL at 10,000 feet. Key is to keep afr's in check. Its a ripper. I did loose a piston a few years back when all I had was a cheap boost gauge and riding at home at sea level. It was detonation due to high compression ratios. As far as grenade, I am yet to see one also.
stingray719
1,698
670
Colorado Springs, CO
stingraymods.com
Yeah I had two boosted Phazers, turbo I rode last season. Girlfriend rode the 160hp Supercharged last season and part of this. The only ones I know had issues were above 160hp or had issues when ran out of specs.
MTN_VIPER
444
NW WA St.
fourstrokesolutionsllc.com
A buddy had his go down a couple of years ago. The root cause was he had the boost cranked up (don't remember how high) and was running only 50/50 race/pump fuel at the time.
He rebuilt it with new rods, lower comp pistons and now runs less boost to be on the safe side. The sled has been trouble free since.
As far as I know he has restrained himself from dialing the boost up farther, but did say that if he did that he would run straight race fuel in it!
A
ak
2,776
723
I had one go, to much boost 16lbs with a head shim, on race fuel. It would creep in to the 18 lb range at altitude. Mcx kit, The rod failed and out the block it went.
roughrider99
1,805
252
83
34
Fernie,BC
Just as reliable as a nytro, prob easier to blow up since it doesn't handle big boost and when it's 160hp @ 14lbs. I know I would wanna crank it up " oh just a few more lbs wont hurt". Boom
I still like the phazer and will eventually be looking into options such as sleeves or a ductile iron block. 200+ hp phazer would be amazing
M
MRFUSION
Aug 8, 2008
162
27
Peace River AB
I have a question off topic here. I just bought a wrecked 07 MCX Phazer for my wife and built the engine with no head shim and am looking to run at 5psi. Testing it I am unable to get below 6.5psi without having my waste gate slightly open, I was going to port the wastegate to help me out. Anyone try this route on this turbo before. Should be a fun sled for her. Thanx
Shad
roughrider99
1,805
252
83
34
Fernie,BC
Porting the wastegate may help but maybe not enough if you want 5 psi, you should be able to pic up a new wastegate for fairly cheap
M
MRFUSION
Aug 8, 2008
162
27
Peace River AB
I was thinking of that but when I got this wreck it the turbo was damaged and its a one off Mitsubishi that MCX gets made for them, had to bite the bullet on the cartridge and go through MCX. I will check on the actuator see if that's easier. Thanx
H
HANDSOME
1,400
177
Pouce Coupe
I dont mean hijack but which do you like better ?
27,616
I have thought about boosting one of my phazers many times, but that rumor of GRENADING was dang prevalent here on SnoWest.
stingray719
1,698
670
stingraymods.com
I thought we put that rumor to bed Christopher, the only ones that are real not rumors were set up wrong. Funny how rumors become fact and people don't ask the poster "did it happen to you or see it in person?"
I sold both mine so I no longer care about Phazers it just kind of aggravates me when rumors are more real than fact.
stingray719
1,698
670
stingraymods.com
Two different animals.
Turbo Phazer nice take off and great top end. Only Turbo I know of was MCXexpress and I had a less than pleasant experience.
Supercharged Phazer will pull yours arms on take off and instant power after letting off and acceleration.
If I did it again, Supercharged for sure on a Phazer.
27,616
That would be the route I would go as well.
I would think 6-9lbs would be pretty solid on that little sled.
We should get MATT from MPI to jump in on this and offer his comments.
27,616
I still have two of them and we ride them pretty much every weekend.
There always seems to be someone who wants to come riding that doesn't have a sled and they are darn near bulletproof little sleds. So they are perfect loaners.
Matt@MPI
293
264
My take on the Phazer is that Yamaha squeezed out everything they could out of that little motor from the factory unlike maybe the Nytro or the Apex. So when you add boost it becomes more on the edge as far as reliability goes. The Phazer with boost requires more of a hands on experience. The Nytro and the Apex and now the Viper motor can take a lot without any problems.
