This thread is to address problems some folks are having with their 2014 Silber kits but will contain good info for all the other kits as well.
Install tips
Make sure you put the injectors in the right side of the motor. The white wire with a yellow stripe goes to the mag side injector. I also use harness tape to cover the connector and any exposed wires similar to the factory one you are taking off.
Make sure you gut the factory air box.
Make sure your oil pump is plugged into the dc power plug and not the ECM power plug
Triple check all your wires and hoses are secured and will not rub. I use velcro to secure everything.
Gap spark plugs to .018-.020. I use NGK BPR9ES.
Clutching, I set them up with a pink spring, and a red in the heel, and red with a thin washer in the middle and tip. I run the 44/48 side of the helix as well.
Boost, I run 8-10 pounds from 8000-11500 in Colorado on 25% 110 VP / 91 Pump.
The sleds that I have done are stock 2011-2014 Pro's. By stock I mean just that. No different track, gearing or anything else.
Double up y-pipe springs and ensure exhaust donuts are good.
Flashing the ECU. This only applies to the folks with 2013's that did not send their ECU's in to Justin. Menu>Install Tuning>Accept disclaimers>Install Custom tune to vehicle>Select newpro21.atv>It will tell you its complete and to cycle the power if it worked correctly. If you mailed it in it was shipped to you ready to run.
I will work on troubleshooting tips today.
If you are having a problem copy the following, Fill it out and PM me. Please be honest or we may never be able to resolve the issue. We had one guy put a BB on and didn't say anything because he didn't think that was his issue. I need all the info.
Year Sled:
Miles:
When were the power valves cleaned last:
Did you flash the ECU with the BD or was is shipped to you flashed:
Is the check engine light on:
Any pre existing conditions:
Have you ever adjusted the TPS:
Silber Dealer you bought from:
Did you self install or did the dealer do it:
Update kit or new kit:
Turbo type (ie KpA, standard, Garrett etc):
Track Type and Length:
Any changes to the factory engine:
Clutch setup:
Boost level:
Fuel used:
Was the kit installed taking into the consideration the notes above:
Detailed description of the problem. Videos are awesome.
I am going to correlate the data and try to get something figured out.
Install tips
Year Sled:
Miles:
Clutch setup:
Boost level:
Fuel used:
