Also, when you power the ECM plug as mentioned above, you can check reference voltage (5.0vdc) at the red/white wire on the clear connector that hangs down above the head (that is not used or plugged into anything). Keeps you from back probing two very tight spots on the ECM.
Also, if u do use a paper clip, I hammer one down, and file it to a very fine smooth point, to decrease chance of damage. A sewing needle can be used for back probing, but will give you very little room to attach a test probe.
You're voltage readings may be off a bit, so this check may be helpful, but usually when TPS go bad, the potentiometer within is what goes bad, so you'll definitely want to do a analog sweep test of the TPS as well.
