I know EZ ryde is not the greatest skid out there but over the years I have got it set up decent enough that it meets my needs.
The one part that keeps failing is the hose from the rear shock to reservoir. In approx 5000km it has pulled off 3x........the third time being today just riding across fields. Hose runs from top of shock to reservoir mounting to the side of the tunnel. Tricky to get it mounted just right so the track is not hitting it but a lot of snow/ice is smashing that cable all the time.
Christain at ez ryde has fixed it every time and done an overhaul on sock as well as I have to send in the entire unit (oil and pressure). Around 60$ total shipping and usually 60$ in parts rebuild. Getting annoying to have to keep fixing this.
Reservoir is mounted correctly as they describe. It will last around 1000-1500km then just disconnects. I just had the skid out last week and it looked fine.
Is there some stronger connection hose or better shock that would work? Would really hate to start over again with a different shock as I finally have this one set how I like it. (spring and valving).
I also have no intention of swapping in a different skid either at this point.
Wondering if others have had this problem and/or have a solution.
