Removing trackshaft??
09 M8 I have a antifreeze leak coming from the clutch side under the tunnel (directly behind the diamond drive) under the hose cover .
I have the skid out, diamond drive out, brake caliper off, brake jam removed. But the trackshaft will not come out of the brake housing.
What am I missing that the track shaft will not come out of the brake housing?
Got a 2x4 between hammer and shaft. Is the bearing pressed on the driveshaft? I do not see a snap ring.
Beating the heck out of it, not moving,,,
Thanks for the help
Chancho:
Go to the parts store and get some PB Blaster. Tip the sled up on the left side and spray the threaded area heavily and let it sit overnight or for an hour or so. Then heat the brake up lightly, there are seals in there so you can't hit it with a flamethrower. Then proceed the beating. If it does not shift at all, repeat the process.
why not just unbolt the brake caliper and let the driveshaft hang down out of the way to take the hose guard off?
as well it helps when the sled is on its side and you are beating on the shaft to have a 2x4 supporting the caliper tunnel side to the floor to take away bounce...and what I had to do was get the permatex deepfreeze spray.._minus 40 and spray inside the hollow shaft where the bearings are seated to shrink the shaft abit...but yes as racinstation said..first soak overnight with pb blaster..replace those bearings...
It will come eventually, when you put it back together make sure you coat it with anti seize, then you wont have his problem again.
I heard a mixture of acetone and 2 cycle oil is one of the best penetrants. I forget the mixing ratio. It's on the web so it must be true.
Get a fresh 2x4, and on the ends you drill a starter holes on each edge, then use a few long lag bolts to keep it from splitting so easy.
Also, in the end going against the shaft, put a lag bolt in the end to help hold it in place on the hollow shaft.
The best tool around is found in the BDX dd seal change kit. It allows metal to metal effectiveness without the mushroom tip woes..
