Another NyPro Project
sportsterdanne
Recipe : Pro RMK bulkhead, with Steering, Spindles, Pro and Assault A-arms, Swaybar, Assault WE needle shocks and gripper skis, Nytro cast engine plates, steering hoop, front cooler, Arcti cat brake lever, ski doo Summit tunnel cooler, REV gas tank... more to come
Goal:
Mount Polaris bulk to Nytro plates with Skinz 4,5" forward ski stance. more upright steering than Nytro
Make tunnel with flat top, Summit tunnelcooler, REV gastank with pyramid reinforcements up to steering hoop. Turbo in front of tank tunneldump or move oiltank and do a side exhaust.
Mounting for short (Lynx PPS) and long rear skid and track, removable tunnel extension.
Arctic cat brake lever.
Radiator delete.
will probalbly use the Polaris plastic.
Progress so far.
parts for the build.
Pro Bulk and Nytro plates
AC Brake
Lynx PPS rear skid and Summit X Cooler
Mock up
Started on adapter plates in wood.
Milled in aluminum
Upper attachments in steel, and mock up
Nytro tunnel to get some measurements from.
Testing the Polaris lower plastic
Skid plate out of 4mm aluminum
Welding on the upper attachments.
Thats how far i am at the moment.
And here is another project i made a cople of years ago.
Before
After
A webpage of the bike build
http://hem.bredband.net/buellcustom/
That's more like a mutpro, little bit of everything in that one! Great work though looks damn good. Why the nytro tunnel though?
The tunnel is just for measurements and mounting up the skids. The final tunnel will be flat on top and running boards will be air frame:ish or newer Polaris.
I really do think you should call this sled for Frankensled!
Here you got parts from every brand out there on the factory marked.
Cat brake
Doo tank
Lynx suspension
Yamaha frame and motor
Polaris front suspension and plastic
Vell, a frankensled like frankenstein with parts of pretty much anything :D
Got myself a nose plastic with a small damage on today.
Its white with the cooler hole in it but it was free and its a better start than nothing.
Not much done but today i got a short session in the garage.
Chopped of the stock steering bracket.
I planned on mounting the steering but i have to mount the rear pyramid support first and to do that i have to modify the tunnel first.
Looking good this is going to be a nice ride once its done! You need to get it on a scale once its done to see what it weighs
Thanks !
I will put it on a scale when its done. My primary goal is not to build the lightest "Nytro" first i want it to work and then i might shed some more weight of it.
Drilled some rivets to get the Nytro tunnel to pieces. And then i fixed some banged up parts from the Pro, the left tube and sheet thats in front of the foot. I will probably use some parts of them.
Added som more parts
Pro RMK Console and front pyramid support from REV.
Jackshaft and driveshaft.
Handlebar and riser.
Shaved off the angled corners of the Engine plates.
Got the sheets for the tunnel and started to mount them, got me some Clecos and they are awesome.
Today i riveted the sheets to the tunnel and cut the cooler to right lenght, tomorrow i will weld it and mount it.
guided the hole saw with a broken Wood shelf to avoid the center drill.
I will admit I was skeptical in the beginning... But you're doing an awesome job!!! Keep it up!
tdbaugha : thanks !
I have catch a cold and have fever so i didnt get anything done yesterday, and today i threw down a bucket of painkillers and got the cooler welded but now im ready to drop dead.
Did a pressure test with a piece of hose that i drilled a hole for the blow gun, then i used soapy water and found some leaks that i rewelded.
Welded the REV attatchments to the Pro tubes, And added a black nose plastic and a Pro bumper to the Collection of parts.
it looks like the front REV Pyramid parts will fit as a middle pyramid support.
