So What The He11 Does Work.... Build
B
Boyko
Do big turbos work? Water to air work, I think it should. How about a big A$$ Chinese turbo?
So in a fit of confusion me and a buddy decided to build 2 different turbo kits and glue em to 2 identical sleds. 2012 & 2011 low milage RMKs
1st one is with the classic 2860 .86 garrett, really straight forward kit.
2nd kit is going to be a 73mm .86 turbo that should be on a beet to $hit 86 civic, Have to add a massive water to air set up to give me a edge
So after we strip the sleds we did a quick check on the piston clearance as it has plagued Polaris in the past. Both came out at .006, not the best
way to check but it does get the job done.
Both sleds are getting divorced exhaust on them, my welding did get better but it still sucks, this is a nice pic. The flange I built will fit a few
different turbos, I think I might be changing the 73mm way to soon.
This 200.00 e-bay turbo scares me, keeps me awake at night. I had to mill out the interior scroll section of the turbo 1.75mm, it just was
to tight for a 2-smoker The red part is what I opened up
Watching this one, I have long since thought about a cheap Chinese turbo, build just because.
Not sure I would have gone that big, you might have to pick up a second small Chinese turbo and do compounds. LOL
73mm inducer or exducer? I'm assuming exducer as a 73mm inducer is 1000hp turbo, and would never light. So about the size of a T3 super 60.
Or is 73mm the turbine measurement?
It is a 73mm exducer on the compressor, I have to pull the housing off to do some mods to it. Seems there are a few things I have to change to try to get this thing to work on a 2-stroke. The hot side was supposal the same specs as a 28 series Garrett.
So it should be right between the 2871 & the 2876, other then it is probably copied from old garrett "T series" wheel tech, so it will probably spool like the 2876 and flow more like a 2860 on the compressor side. :face-icon-small-con
But for a $200 turbo I think it will still be a good shoot out, and I am glad you are doing it.
Here is a pick comparing a garrett 2860 with what I am trying to work with, the garrett has 2 less blades on the turbine and a less aggressive sweep on the tip
Kind of hit the wall with this turbo, the compressor wheel is 82mm wtf? Who would build this, 54mm turbine to a 82mm compressor. Dam you e-bay
I am hoping to get a turbo from one of the kit builders, I do kind of want to get away from Garrett just for a change and buddy running one on his build
You alway have good advice:face-icon-small-win
So after a few spiced rums to settle me down I decided to run this thing, It’s only a hour or 2 or 3 to swap it out with a real turbo. I have to shoe horn this thing in so I cut the inlet down
In this picture you are measuring the exducer part of the wheel. You need to measure the inducer side to determine the size of the wheel.
None the less, this is an interesting build!
Garrett numbering uses the compressor exducer for the sizing.. so 2871 is a 28 exhaust side and a 71mm exducer on the compressor. so indeed. that is a very oldly put together turbo..
Glad to see you got things under control and gonna have fun with it!!
inducer on a 2860 is 47mm this was 57mm a beer can is 62mm :face-icon-small-ton
Here is the garrett and the dumb turbo
I will have fun with it if it spools below 7900 rpm LOL
Here is a pick of a mock up it is a tight fit, Justin Silber has been helpful and sold me a few key pieces
Here are the air boxes we are running velocity stacks in both, one is a water to air.
And the heat exchanger
That is a very strange turbo, it is like someone put a GT35 compressor on a GT28 turbine, so a GT2882 if such a thing existed. I would be more worried about surge then where it will make boost.
I would expect also that you will run out of turbine long before compressor. I am assuming you will be monitoring drive pressure? You may only get 5 or 6psi out of that cdm turbo before the drive starts to sky rocket, with that tight exhaust and big compressor.
Now that it is a $50 turbo you really have nothing to loose. LOL
I love watching your builds, looking forward to updates.
Ya it is a weird one...... The seller said that is what the market was demanding? It does have some balancing grinding on it. I think the exhaust pressure will be high (+5psi before boost :heh:) as it is tiring to get the thing spinning to around 80,000 rpm at that point the boost should rocket up pretty fast. Hope I do not have to pull to much fuel off the bottem.
Starting to stuff thing in the sled for the last time here the 2860 sled with the air box in and the t-map mounted to it.
Mine is getting a little crammed up ……... So I had to cut it up
Had to run the cooling for the engine through the frame, forgot about all the
hoses when I was mocking it up
I am using a micro pump for the water to air, its small but it really cranks the
fluid through and only 1.2 amp draw
The water to air is a semi close loop, engine coolant out of the throttle
bodies (via 1/4” line) into the turbo from there it goes into the water to air
and then back to the factory surge bottle
