New Sled Deck
egesledder
New Mountain Kings Fab powder coated sled deck. I've got both a long bed and short bed deck for sale. It's very well designed and built. Steel construction, but around 400 lbs with ramp in short bed trim. Two people can easily load this deck into a truck, and I've unloaded it by myself. This is a VERY rigid setup, strength was not compromised for weight loss. Ramp is super easy to use and stows away under the deck.. Short beds will fit any 6' bed or longer, long bed version will fit 8' beds.
-Short bed: 8 foot deck with 12" tail
-Long bed: 9 foot deck with 12" tail
-10 foot ramp on both
-Angled headache rack
-Rugged powder coat finish
-EZ-slides ski guides on ramp and deck
-Non-slip coating on deck surface; makes it SUPER grippy while tying sleds down
-Aluminum T-bar tie downs included.
-T-bar tie down nuts on both sides and center for hauling one sled
-Turnbuckle mounts in all 4 corners, turnbuckles included.
Pictured below is the short bed deck.
$1850. Give me a call or PM me if you're interested. I can deliver to the Denver area for free, depending on distance. Thanks for looking! Drew 260-615-7970
Both decks still for sale, although the short bed one may be sold. These are the last two I'm going to make this year, so get one while they're here!
Pics
Could u take some pics of underneath the deck, where the ramp goes and the cross bracing underneath?
The reason I ask is because I have a 50 gallon slip tank in the front center, 3 ft by 3 ft in the front center and want to know if it will clear.
F250 short box.
Updated the pictures, does that help? You have close to 4' between the uprights, so your tank would still fit in there, but you would have to put the tank behind the front cross member.
Let me know if you have any other questions and feel free to come check it out if you're in the area.
