Cheap way to do it...
Take PVC pipe 1/4".
use a pvc "T" with the bottom cut half off length wise so it will go around the bumper.
Take 2 screw in clamps to secure the T to the bumper.
Take 3-4ft of pvc pipe glued into the T, so the pole will be right infront of you.
Then you can use the basic gopro black screw in mount (dont know what its proper name is) and just plug and glue that in to the top of the pvc pipe.
Camera should be right in your face.
Not professional but itll cost you less than $5.
Hey G do you have of pic of this on your sled??
Thanks, Dallas
Take PVC pipe 1/4".
I actually use the GoPro seat post / handlebar mount with it mounted to the front bumper of my Pro. It works and it's out of the way but I am looking at an extension for a little better view. I also have flat mounts on the top rear of the tunnel on each side of the tail light. You can mount the camera for a complete rear view or facing the riders back side.
I can post up some pics to give you an idea.
Sent from my DROIDX using Tapatalk 2
