The start to my water to air intercooler setup
TWARD700
Very nice idea. Just an FYI, Fabcraft used to have tubes like that with extrusons on one side for added surface area. Not sure what track clearance allows there.
Here's a few more of the inter cooler mounts welded in and the water pump mounting .
Sure looks like you put allot of effort into it man. well done.
On your next build, do like I do on the xp's. cut the two down spars and wled the intercooler into them . it makes for a stronger chassis and allows you much more room for the headlite or hood.
I will post some pics in a month. i am working 60 hrs a week so my sled time has been cut down to zero !!!
Thought about it didn't have the space under the tank and a didn't want to have to take the water lines off every time I need to take off the air box.
Its a well crafted piece of engineering by Mr. Ward.
I will show you guys pics on another thread in a month when I have time to get back into my shop.
For real, twards set up is beautiful. will work and will allow access to his carbs with minimal hassle ( none ).
He will see 60 degree or lower charge temps and be deto free !! Again well done..
Gus
