G
gman086
Rarely do I tout aftermarket mods as absolute "must haves" but I have found two for the Pro that are and both come from Madsigntist on the forum. Both are reasonably priced in comparison to similar mods I've seen on here.
1. EZ Boards running board inserts. As most of you know by now, the Pro is sorely in need of better running boards and finally got them for the '13 model year. For those of us with the '11's and '12's THESE are the answer! No need to go with expensive Airframes or similar that cost a small fortune. They are very nicely crafted plastic inserts that prevent the snow from sticking and they REALLY work (I was skeptical) with NO cutting! You just drill holes and rivet them in - takes minutes. They are even routed underside where the existing rivets are so they lay completely flat (attention to detail is excellent). And they DO provide more support - my sled is noticeably more responsive to foot pressure with these as they basically stiffen your stock boards! And, for a small upcharge, you can get the plastic footwell block-offs too for half of what the others are selling for (first pic). I honestly couldn't be happier. Second pic is all the snow that gathered after a long sidehill pull without even swiping my feet once - just stopped and took the pic. Third pic you'll notice some snow build up at the rear (where I wasn't standing) but it comes right off with a quick swipe of your boot as the snow is NOT stuck on like with the stock aluminum boards! Bonus - makes your sled look SICK in combo with vinyl tunnel wrap! Wrap and Stomp Grip also highly recommended for keeping snow from sticking to the sides and more control of the sled.
2. Mad Fab Designs Gauge Lifter - Adjusts the angle so you can see the gauges while standing AND vents quite a bit of heat. Bonus - acts as a helmet warmer for when you have prolonged stops, I LOVE it! Last pic you can see the gauge lifter and the fact that my running boards are spotless.
If Matt comes up with anything else, I want to know because this guy is a genius!
Have FUN!
G MAN
PS - Also filed the outer grip prongs flat like some SW'rs recommended - works perfect! No more sliced up boots/pants and I didn't notice any reduction in grip. Another MUST DO free mod!
![IMG_0219.jpg IMG_0219.jpg](https://www.snowest.com/forum/data/attachments/132/132929-f8e7bf6c095e0f1b94cde3b55effecb9.jpg?hash=-Oe_bAleDx)
Have FUN!
G MAN
![IMG_0228.jpg IMG_0228.jpg](https://www.snowest.com/forum/data/attachments/132/132901-83a71fe66d395462cc4333ff34cf3a34.jpg?hash=g6cf5m05VG)
![IMG_0240.jpg IMG_0240.jpg](https://www.snowest.com/forum/data/attachments/132/132907-a75665221121d6a932b4e96cfe01386f.jpg?hash=p1ZlIhEh1q)
![IMG_0241.jpg IMG_0241.jpg](https://www.snowest.com/forum/data/attachments/132/132914-afee4b0fe75e6ea745f923de602194cb.jpg?hash=r-5LD-debq)
