What are you guys using to haul gear(Beer/food/Sleeping stuff) in to the mountains. I heard Husky. Pics would be appreciated.
I have one for towing our stuff into my cabin. Mine started out as a normal tow sled. I think I bought it from Polaris in 2004. It didn't carry enough in one load, snow would cake everything, and it would roll over around every corner unless I went 5mph. So went down to a local metal shop and bought aluminum mesh sheets for the sides. Cut and bolted them down. Used right angle hardware to connect the top sides of the mesh to hold the corners together. Then I bolted on a bunch of hooks for the shortened truck bed net. Finally I addressed the stability. It always falls over and being higher now would be even worse. I took some old hifax off an M8 and cut it down to size. Used right angle hardware and slipped though the hifax just like the rail on a sled. Perfect fit. Then drilled and bolted the right angle onto the hifax and tow behind. Finally I bought some hard durable plastic play balls at Walmart. Cut a hole on the end and slipped the hifax into the middle of the ball. Then secured from one side of the ball thru the hifax to the other side of the ball with a long bolt/nut/washers. This give the stabilization arms a nice round area to dig into snow/pow at any angle and not catch and toss the sled around. Keeps it upright when it catches and will not roll over now.
That thing is huge. Looks like you can carry the whole garage and dry too! What is that thing?Like this?
Or this?
