Hey guys, I decided to increase the oil pump flow rate while I had the pro torn down for other projects.
It is kind of a chore to get to, but easy to adjust once you get access.
So in order to get to the adjuster easily you must:
Remove side panels, hood, and rear plastic cover
Remove seat
Remove Gas tank
Remove airbox(which is tight to get out!)
-I had the Oil tank, clutch cover, and clutches off to get the most access, but you might be able to get to it without taking out those parts.
Once all that is out of your way, you will need to screw IN (Clockwise, right tighty) the set screw on the throttle body linkage shown here:
It takes a 8mm (or a 10mm, cant remember lol) to loosen the back up nut and then a flat blade to screw in. You have to push the linkage down like this to adjust it:
This is what it looks like normally
One thing to note is that the oil pump arm set indication is kind of hard to read compared to older Polaris pumps. This is due to the indication arrow being inverted rather than extroverted. So lining up the arrow to the line on the pump's body is harder to see, especially through the little space between the throttle bodies.
Hope this helps!
Remove seat
Remove Gas tank
![9b89837d.jpg](http://i238.photobucket.com/albums/ff236/polarisrider_01/9b89837d.jpg)
![82e4287a.jpg](http://i238.photobucket.com/albums/ff236/polarisrider_01/82e4287a.jpg)
![64b17c26.jpg](http://i238.photobucket.com/albums/ff236/polarisrider_01/64b17c26.jpg)
![5116fdf2.jpg](http://i238.photobucket.com/albums/ff236/polarisrider_01/5116fdf2.jpg)
Hope this helps!
