Installation and Review: Simmons Gen III Flexi-Ski
27,371
Last May I placed an advance order for a pair of the Simmons Gen III Flexi-Skis for my Yamaha Nytro after having heard some wonderful comments from test riders who had access to prototype versions last winter.
Today, my order arrived!
27,371
As with most good things, the skis arrived in a plain brown box!
Skis came with NO packing material, just slid into the box.
One thing that really surprised me is that there is NO documentation of any kind. Not so much as a note from Simmons, just the box and the skis.
27,371
In the box were 2 mirror image skis.
I say mirror image as they are identical, but OPPOSITE.
They is a Left ski and a Right ski!
And the two skis are CLEARLY marked so there is no mistaking which one goes on which side of the sled.
27,371
The bottom of these skis is clearly what sets them apart from everything else on the market. They have dual keels that are Asymmetrical, which is why the skis are labeled Left and Right.
27,371
Yamaha OEM Ski
New Simmons Gen III Ski
Total Weight Gain = 2.2lbs PER SKI
So about 4 and a half pounds more on your sled.
27,371
Next I will get the old skis off the sled and mount the new ones.
This weekend I should have 3 days of on trail and off trail riding at the SnoWest Forum ride in West Yellowstone to TRY out these new skis.
Scott
Scott Stiegler
69,618
11,737
W Mont
So when they are mounted is the short keel on the inside or the outside?
27,371
Sled the sled lift in and jacked her up a couple inches off the ground to remove the OEM skis.
The OEM ski comes off with very little effort.
27,371
With the OEM ski off the sled, the rubber bushing has to be removed to be used on the Simmons.
Nut comes off and the bolt slides out
And the OEM Bushing drops right into place.
PAY ATTENTION when you do this, as the bushing is NOT symmetrical!
Make sure you insert it in the same orientation that you took it out of the OEM skis or you will end up doing this whole process twice like I did!
27,371
With the use of the Sled Lift I slowly lowered the spindal back down into the bushing only to find that it did not fit.
With both skis the new cradle was about 2mm too narrow so the original mounting shaft would NOT fit down inside the ski. A gentle tap with a hammer opened both of them up wide enough to allow it to slide into place smoothly.
27,371
With both skis mounted I quickly noticed that all was not well.
The Left ski was almost perfectly flat, while the right ski was 15 Degrees tip up.
I removed both skis, took out the rubber bushings and rotated both of them 180 degrees and remounted the skis. This left both skis with about a 5 degree Tip Up orientation.
