New Lighter Weight Camoplast Challenger Extreme Tracks
Camoplast introduces new lighter weight Challenger Extreme mountain tracks with improved lugs for even better performance in deep snow conditions.
With a weight reduction of 4 pounds (#9175M), the 2011 versions of this benchmark high country track weigh approximately 8 per cent less than the equivalent models being replaced.
Featuring the traditional Challenger design of outside edge lugs on one pitch followed by a center lug on the next pitch, the new Extremes are equipped with a 2.5-inch no-tooth lug. Every lug incorporates support towers in the center and on the edges for excellent lug support, but the section between the towers is thin and flexible under load to improve flotation in soft, bottomless powder.
The new Challenger Extreme tracks are available in:
- 15-by-153-inch #9174M
- 15-by-162-inch #9175M
- 16-by-162-inch #9176M
With internal drive and a 3-inch drive pitch, they will fit Arctic Cat M-series snowmobiles equipped with Diamond Drive without drive or suspension modification, as well as fit other mountain models from other manufacturers.
This new series of track is a "Drum Molded" track as are the majority of the Camoplast Mountain Track line-up.
This photo shows the 9944M, which is the 16" wide track... this is the only one in this lineup that does NOT have paddles to the edge.
