Anyone know the weight difference between the 2 tracks? Also do you have to switch out drivers to put the pclaw on the new Pro RMK? Thanks!
Does anyone know if you have to change out the drivers for the challenger extreme as well?
Mike,
Are the 2011's going to have the same drivers though?
Is there enough clearance for the 3 inch?
The weight diff is about 9 lbs. with the 3.0" pitch 162" CE 2.5"
10 lbs in a 2.86" pitch 163" CE 2.5"
The track weight is about 48LB
AK... the clearance is the same as the current RAW chassis... to get more clearance, as 'vida said... you would go to 7 tooth 3" pitch drivers and a 156 or 162 CE 2.5"
14eer, the The 3" 162 & 174 are supposed to be out this summer ... AND, Robbie at Avid said he Might be making a billet extended chaincase for this thing... It will be a pricey upgrade... about $1100 for the track at discount and prob $800-ish for the case/cover.
