Good topic Shift_Fast!
Mblanken881, I think your track is "ballooning" as it travels through the tunnel. I was going to mention that can happen if your track is too lose. If the track is too lose all that hanging track still has to rotate around the skid and with the centrifugal force trying to throw the track out and away from the skid, it's like a wave that travels along the moving track. That bump you came off helps to build the wave.
If ballooning is the case you'll notice it in the powder when you are jumping something and as your front end comes up and you keep the throttle pinned, you'll feel and hear the ratcheting. Mine was doing it so bad on my last sled that it was ratcheting with extroverts!
Before extroverts I would loosen the track until it ratcheted and then tighten it a 1/2 turn on each side. With extroverts you can run the tracks much more loosely than before but, ballooning and track stabbing become the limiting factors.
Lose is good, too lose will let you know by rubbing in the tunnel or ratcheting under power. An anti stab kit will give you peace of mind and will help you find the correct tension without having to worry so much about a catastophe.
