2010 M8 oil tank warpage
Coldfinger
Ski-Doo BCA 509 Artic Cat
How many of you 2010 owners are seeing warping of the tank neck?
I have applied reflective tape to the right side of the tank and it still warps in the neck area. I don't overly tighten or cross-thread the cap either.
Another observation - the neck area has two thick seams. The front seam is very thick, like 9/32" from inside of tank to outside of threads. Is this the way all the 2010 tanks are? My buddies 2009 hardly has any seam thickness at all.
His name is DAN03REV on here, sells them for like $15 shipped.
Had one in my new tank all year so far without any problems on a 07 M8. I did clean up the seams on the threads and on the inside so the insert would fit.
Oh yeah and good luck getting the torx bolts that hold the tank on out. Cat was so smart here that they even put loctite on them.
hey guys ... Coldfinger mentioned the seams from the molding process were a bit thick on his sled .. noticed one reservoir at the dealer looked the same .. here is my suggestion .. take a hot blade and press the seam flat so insert will install easier .. or use hot blade to shave away some of the excess plastic .. guys are having to do the same on a SKIDOO REV chassis .. some are just chipping away excess plastic with a utility knife .. simply heating the blade prior to doing this so the cut will be cleaner and easier .. removal of 1/16" on each side is all is needed at most .. 9 of 10 guys are not having to remove any plastic .. inserts are made to be a tight fit, so be careful removing any plastic from reservoir opening top edge .. insert will come with an o-ring for a tight seal .. email if interested in ordering .. i have many aluminum tank inserts in stock .. ship daily
Whats your email? I need one since I'm on my 3rd bottle already and its warping now too. Its been a real pain in the neck and its been an added expense.
Cat should send 1 to every buyer! At the Least!
I got the oil tank insert and it lots like it is going to work awesome and for the price you can't beat it!!!!!!! Thanks a lot!!!!!
We will have our "fix" for this oil tank issue on display at the Denver Snow Show... Come check it out..
We will also be unveiling another awesome product for both Cat and Doo .. if we get them finished by then..
In any case, please come visit at the Denver Show..
Kelsey
:thumb: .. multiple orders coming in daily .. parts going out same day if not the next .. guys in CANADA are receiving orders within 2 weeks of delivery ..
AC 2011 tanks have a new part number and a much cleaner filler neck.
The seam is trimmed and the neck now fits into the cap recess like it should.
So the 2011 tanks look just like the 2010 units but the thick seams in the neck area have been reduced/eliminated, right?
I'm just curious because I was leary about shaving down the thick seam for fear of compromising the structural integrity of the filler neck area/seams. Didn't want to split a seam.
Was looking at an 2011 hcr today. They have a heat sheild around the oil tank filler neck now.
Are the 2011 heat shields diff than the 2010 M sled shields? If not, then they probably won't do much better.
Maybe sleds that aren't ridden in deep powder don't have as much heat under the hoods because the vents don't get plugged with snow, therefore maybe they don't have as much warpage.
I get the idea of what is taking place, but does anyone have any finished pics of the oil tank with the insert in it? Sometimes I like to see, before I order!!!! Thanks!!
i am gonna try to get to local dealer this week to put one in a new sled .. will take pics to post up ..
waiting on an order of o-rings to show on the UPS truck .. thank you guys for preseason business .. my distributors across North America have kits on the shelf .. let it snow !!!
sleeves for Arctic Cat now have a thinner flange and shortened in length .. this will allow oil cap to be turned a bit more ..
