diamond drive gear ratios???
skidooboy
is there a ratio conversion for the gear ratios for final drive?
i am used to the chain, gear, driver method with final drive ratios like 1.73, 1.80, 1.95, 2.01, ect....
might try to gear ours up alittle for trail riding seems to be geared low for high elevation deep powder riding (what it was designed for). most of our riding is alittle higher speed on and offtrail bush road riding. dont want a drastic change as i like how they perform in most conditions, just a change to lower cruising rpms for fuel economy ect... any recomendations?
first time gearing the DD's how hard is it? i have the service manual. ski
Diamond Drive Gear Ratio Formula
This formula is to figure overall Diamond Drive ratio only, this does not take into consideration such variable as clutch diameter or driver size.
The formula is as follows;
Transfer Gear / Input = A then A x 2.24 (Planetary Ratio)= Overall Diamond Drive Ratio
Example:
68/52 Gears. The 68 is the input gear (always listed first, clutch goes on this gear). The 52 is the transfer gear so….
52 / 68 = 0.764 x 2.24 = 1.71 Overall Diamond Drive Ratio
gearing
Depending on what chasis you have the M-series your stock ratio is 57/63. Crossfire is 60/60. depending on which one I wouldn't go more than two to three steps either way in gearing. so if you have the 57/63 gearing I would try the 60/60 gearing it makes a good impact in what your looking at doing.
gears
personal preference really, going 60/60 theoretically will give you more top end speed but sacrifice low end power or even bogging could occur in deep powder. But considering you have a long track with 2" paddles im not sure what to say it will help with top speed and keeping the rpm's down if you stay on the trails.
