Guidoxpress 05 RMK 900 Build!
5.00 star(s)
guidoxpress
ok..
so I FINALLY got to where i could snap some pics..not the best cause it was pretty sunny, which makes sense..but not when your only camera is on your cell phone :rolleyes:
Most of the work was done on a severed ACL, torn Miniscus and in a leg brace from an Orthopaedic Scope 2 weeks ago..so would like to thank the Airforce Fire Dept. for giving me 2 weeks off to "recover" ;)...but it will come back to me in April when I get ACL surgery :(
but you get the idea...
I have a few loose ends that need buttoned up, and waiting for 2 parts yet..i will post pics of those when i get them installed...
still need to:
--install ZBROZ 09 swaybar bracket AND 09 swaybar
--bleed coolant
--figure out why my brake light on my gauges is on when the brake is NOT applied :confused:
--get longer rivots for the skidplate :mad:
--align front end
--install tie rod boots
--re-torque clutch a few times
Here is my list of parts on the sled..and where you can find them if you are interested..if they are not OEM parts!
Venting
•Longtracks Edge Side Panel Vent Kit (www.Longtracksedge.com)
•MoFlow Dash Vent Kit (www.Moflowvents.com)
•Mountain Fit Hoods, Hood Vent kit
BODY
•Black IQR Hood (http://stores.homestead.com/williammoore/StoreFront.bok)
•SPG Seat Post (www.sledsolutions.com)
•Custom Black Seat Cover
•SPG 09 Front Bumper (www.sledsolutions.com)
•09 IQ Center Console
•09 IQ Front End Conversion (www.FTXMotorsports.com)
•09 OEM Skid Plate
•Custom Black Smooth Lined Tunnel (SuperLiner-Bedliner)
•Black Powder Coated Engine Support Braces (done by myself)
•Black Powder Coated Recoil Housing (done by myself)
•Black Powder Coated Better Boards (www.snowmobilebetterboards.com)
•Black IQR Windscreen
•Black Skinz Rear Bumper
•Black Polaris handguards with Billet mounts
•Rider Select Delete Kit (Polzinhunter here on snowest)
•ProTaper Handle Bars (www.Ebay.com)
•09 Dragon 90 Degree Bar Hooks
•Fastlane Hood Strap Kit (www.Flaneinc.com)
•Custom UHMW Side Panel “RMK 900” (Polzinhunter on forum)
•’06 RMK 900 DRAGON “166 Track” Decals
•Pro-Armor Tether Cord
•Dzus Fastner Kit for Side Panels
•Fastrax Billet Throttle Block (www.FTXMotorsports.com)
•Snowy Mountain Lefty Throttle (http://snowymountainwintersports.tripod.com/index.htm)
•RSI Hi-Power Grip Heaters (www.RSIRacing.com)
•Billet Pull Handle (www.Ebay.com)
•BoonDockers Light Resistor (www.Boondockers.com)
•Gripper Skis
•SLP LED Tail Light Bar (www.startinglineproducts.com)
•Custom Made Gas Rack
•CFI LED Adapter (www.Bluhmenterprises.com)
•PowerMadd Extended Brake Lever (http://www.parkeryamaha.com/powermaddbrakeleverforpolaris.aspx)
•AMP Billet Gas Cap
•Timbersled Gauge Bracket (www.Timbersled.com)
•Polaris Underseat Bag
Engine
•Custom Billet Chaincase Cover (Polzinhunter on forum)
•Mountain Fit Hoods Intake Shelf (http://stores.homestead.com/williammoore/StoreFront.bok)
•’06 Rear Motor Mounts
•CompFusion Front Motor Mounts (CompFusion on forum)
•Custom Solid Billet Front Cross-Member
•SLP Push Arm (www.startinglineproducts.com)
•SLP Torque Arm (www.startinglineproducts.com)
•SLP Pipe (www.startinglineproducts.com)
•SLP Y-Pipe (www.startinglineproducts.com)
•SLP Billet Cylinder Head (www.startinglineproducts.com)
•CPI Racing Stinger Can (www.CPIRacing.com)
•FBF Throttle/Oiler Cable (FatBoyzFrenchy on forum)
•BoonDockers Nitrous (www.Boondockers.com)
•BoonDockers Control Box (www.Boondockers.com)
•HYVO 18/40 Gears
•Royal Purple ATF Chaincase Fluid
•Updated TPS Wiring Harness
•Armor Cord Heavy Duty Pull Rope (www.Armorcord.com)
•FNI Intake (www. Firenice.us)
•Black Powder Coated Belt Cover (done by myself)
Suspension
•Fox Floats Front Shocks (www.Foxracingshox.com)
•Fox Float Roost Guards (www.Foxracingshox.com)
•Walker Evans Rear Track Shock (www.Walkerevansracing.com)
•RYDE FX Front Track Shock
•225lb Front Track Spring
•MMP Freedom Axle (www.Mountainmachines.us)
•MMP 9” Billet Big Wheel Kit (www.Mountainmachines.us)
•MMP 5 ½” Idler Wheels (www.Mountainmachines.us)
•ZBROZ 40” Wide A-Arms (www.zbrozracing.com)
•ZBROZ Black Billet Spindles (www.zbrozracing.com)
•ZBROZ 09 Sway Bar Bracket (www.zbrozracing.com)
•‘09 Sway Bar
•Custom Billet Tie-Rods (WIMPY on forum)
•HOLZ Billet Rail Brace (www.Holzracingproducts.com)
•07-up IQ Steering Boot Covers
•Ice Scratchers (SummitSeeker on forum)
•166” Series IV Track 2.4” Paddles with all windows punch/ported
Clutching
•Team TSS-98 Secondary
•66/42.46 Twin Trax Helix
•2 Derlin Washers in Secondary
•Black/White or Red/Pink Secondary Spring
•3211115 Drive Belt
•Balanced P-85 Drive Clutch
•74g MTX Weights with 2g in outer hole
•Green/Pink or Blue/Pink Primary Spring
•Tri-City Performance Secondary Clutch Fan Kit (no longer available)
•Black Powder Coated Primary Cover (done by myself)
•Black Powder Coated Secondary Cover (done by myself)
MISC
•Warm-up Stand (www.Easymovecarts.com)
•EZ Sled Lift (www.Easymovecarts.com)
•SLP Clutch Press Tool for Primary/Secondary (www.startinglineproducts.com)
•SLP Clutch Holding Tool (www.startinglineproducts.com)
Wish List
•VE Boondocker Tunnel
•SLP Cylinder Porting with Decompression Hole Plugging
•2poor Rear Motor Mounts, Torque Arm Assembly
•Timbersled sway bar block off plate
•Anti-Stab Kit
•Anti-Rachet Drivers
•Fully Clipped Track
•Heavy Duty Torsion Springs .377/47 degree
•Rebuilt Stator
•Updated 32mm Crankshaft
•Torque Master I Crank Modification
•ZBROZ EXIT shocks ALL the way around or Timber Sled Mtn Tamer Skid
•Black Powder Coated Skid
•SPG Black Powder Coated Rear Bumper
•Black Polaris Hand guards with Black Billet Mounts
•KOSO Dual EGT Gauges
•Innovative AF Gauge
•FTX Carbon Fiber Side Panels
•FNI 09 Hi-Flow Shock Vents Black Powercoated
THANK YOU LIST
--My wife RACHELLE for not leaving me and letting us go broke and eat Ramon Noodles all year!!
--Kreg Polzin (Polzinhunter) he is absolutely VITAL to me and is an outstanding guy and great friend, with mad skills and excellent products
--Andrew (Skisucca) for all of his help and great friendship..and for the pressure to finish my sled so we can wreck it
--Eric (MountainHorse) Cause he is simply the BEST basket of info anyone could need, and for his EXTREMELY EXCELLENT HELP that we all need
--Claude (FatBoyzFrenchy) he is a GREAT guy to deal with and more improtantly for his excellent products to keep these 05-06 700/900s on the snow
--Dan (Indydan) he is a GREAT guy to deal with and more improtantly for his excellent customer service and better yet, his crank and clutch work that keep these 05-06 700/900s on the snow
--Colin (Compfusion) for his remarkable front motor mounts for the 05-06 700-900s, and his excellent customer service and better product
--Brad (1200psi) for his excellent clutch work
--Michael (2poor) for his insightful info and experience and help
--Matt Zollinger from ZBROZ for his fast help and products
--Michelle (FreeAgent) for her help with ANY parts you may need
--Nolan Miles (nmmiles) fo rhis help and great friendship even though he is always trying to one-up me
--Rob Heeb (F-Bomb) never had a better experience with a company then with Rob, he is flat out amazing
--Curt (FTXMotorsports) by far the best customer oriented, kindest guy with simply the great prices and TOP notch products we all want/need
--EBAY..for feeding my addiction for hours on end
TOYS
--Wifes sled..2006 RMK 700 159" (pics will be up when i am done with it shortly)
--Green 1998 zx9r Ninja
--Orange 1999 (converted to 2003) zx9r Ninja
--2006 Polaris Outlaw 500
--2006 Kawasaki KX450f
--2007 KTM 450 SX-F
--1984 Honda 200s (3-wheeler)
--1985 Yamaha YTM200 (3-wheeler)
DOGS
--Saint Bernard
--Alaskin Malimute/Husky
--Min-Pin
ahhhh time to buy a real camera sean! So how long did it take you to type all that up?:confused::eek: :cool::beer; talk about specific
HAHA!
it wasnt too bad..i had most of it saved prior so i didnt have to do it all in one day. lol...
camera will have to wait..its sledding time ;)
Looks nice and clean! I like the stinger twin pipe that thing should sound wicked. Also the lefty does it clamp OVER the grip? if so I may upgrade mine I have to cut the grip down and then it always wears the heated wire.
That thing is badd azz fer sure!:beer;
About the brake light staying on, with out the brake on. Make sure the brake light harness under the seat is plugged in completly. I know on my 07, when I did not have the harness plugged in, the brake light in the guage would stay on until I plugged in the harness.
Looking good buddy.....the weather looks way too nice to have a sled out tho.
A run on that ZX would be cool..:)
LOL...bring you bike down here and we will trade for a day ;)
yeh the lever clamps OVER the grips..i was wondering if it would fit, but it does..its pretty nice..just wish i had smaller man hands, lol..
DONT tell me to move my gas tank..cause i dont want to again..lol..sounds good..if i cant figure it out with the light and cfi adapter..i will check that for sure..thanks bud.
Looks good, I see you have a happy button on there.
Make sure you don't use it for loading:D
KSH
