This will be forever a work in process.........Please PM me if you have threads you would like to suggest for this page.
2010-2011 M8
Which Lightweight Can:
http://www.snowestonline.com/forum/showthread.php?t=167406
2010 M8 Oil Tank Warpage
http://www.snowestonline.com/forum/showthread.php?t=211633
http://www.snowestonline.com/forum/showthread.php?t=205205
Choosing a Rear Rack:
http://www.snowestonline.com/forum/showthread.php?t=169573
2010 M8 Low End Bog:
http://www.snowestonline.com/forum/showthread.php?t=187349
2010 M8 Power-Valve Adjustment (Check those cables!):
http://www.snowestonline.com/forum/showthread.php?t=186964
2010 M8 Broken Primary Springs (Something to check)
http://www.snowestonline.com/forum/showthread.php?t=188252
2010 M8 Geo Mod and Better weight transfer
http://www.snowestonline.com/forum/showthread.php?t=198971
2010 M8 Torque Specs and Wiring Diagram (Also works for 2009 M8)
http://www.snowestonline.com/forum/showthread.php?t=218769
2010 Broke the piece where my steering post bolts to the top of tunnel 2010 m8
http://www.snowestonline.com/forum/showthread.php?t=214945
M1000
Adding an extra motor mount to your M1K
http://www.snowestonline.com/forum/showthread.php?t=163693
Adding Electronic Reverse to your 08 M1K
http://www.snowestonline.com/forum/showthread.php?t=230476 (Great Pics on this link)
http://www.snowestonline.com/forum/showthread.php?t=140926
2007-2008 ECU Update to 2009+ Specs
http://www.snowestonline.com/forum/showthread.php?t=137466
09 M1000/CF1000 service bulletin (Posted 10/13/2009)
http://www.snowestonline.com/forum/showthread.php?t=170778
Suggested Gearing
http://www.snowestonline.com/forum/showthread.php?t=100576
Porting
RKT M1000 Porting
http://www.snowestonline.com/forum/showthread.php?t=149742
Other M1000 Porting Options
http://www.snowestonline.com/forum/showthread.php?t=164653
M7
Choosing a Pipe for your M7
http://www.snowestonline.com/forum/showthread.php?t=156228
M7 Engine Mods and Engine Related Information
http://www.snowestonline.com/forum/showthread.php?p=1956115#post1956115
M7 Chassis Mods and Related Information
http://www.snowestonline.com/forum/showthread.php?p=1956694#post1956694
M7 Clutching and related Related Clutching information
http://www.snowestonline.com/forum/showthread.php?p=1956725#post1956725
M7 Suspension Mods and Related Suspension Setup Information
http://www.snowestonline.com/forum/showthread.php?p=1956753#post1956753
General M Series
Chassis/Body
Choosing the right Venting for your sled:
http://www.snowestonline.com/forum/showthread.php?t=164136
Upgrading your 05-08 Bumper to 09+ Style
http://www.snowestonline.com/forum/showthread.php?t=172286
What to do when your hood latch nubs break off
http://www.snowestonline.com/forum/showthread.php?t=194822
Hood Latch nub repair kit from ACAT:
http://www.snowestonline.com/forum/showthread.php?t=232213
Torque Specs and Wiring Diagrams
http://www.snowest.com/forum/showthread.php?t=218769
Suspension
Fox Float Skid Setups:
http://www.snowestonline.com/forum/showthread.php?t=112213
Upgrading your 05-07 rear suspension to the Fox Float Setup
http://www.snowestonline.com/forum/showthread.php?t=85776
Track rubbing on Diamond Drive
http://www.snowestonline.com/forum/showthread.php?t=196052
Skis for M-Series
http://www.snowestonline.com/forum/showthread.php?t=170569
Clutching
Clutch Spring Information (Part numbers, Charts, etc....)
http://www.snowestonline.com/forum/showthread.php?p=2624573#post2624573
07-09 M8 Clutching setups:
http://www.snowestonline.com/forum/showthread.php?t=110734
Engine/Exhaust
SLP Pipe setup for 07-09 M8:
http://www.snowestonline.com/forum/showthread.php?p=493526
Oil Delete:
http://www.snowestonline.com/forum/showthread.php?t=166262
Tunnel Dump Can Mod:
http://www.snowestonline.com/forum/showthread.php?t=177542
Exhaust Temp Sensor: Low Cost Diesel Sensor
http://www.snowest.com/forum/archive/index.php/t-255092.html
Air/Fuel
Choosing a Fuel Controller Box
http://www.snowestonline.com/forum/showthread.php?t=170400
Choosing an Intake
http://www.snowestonline.com/forum/showthread.php?t=172976
Diamond Drive
Diamond Drive Rebuild with Pics
http://www.snowestonline.com/forum/showthread.php?t=300771
Tearing down 2009 Diamond Drive..Upgrading Bearing
http://www.snowestonline.com/forum/showthread.php?t=151644
Reassembling the Diamond Drive (Good Pics!)
http://www.snowestonline.com/forum/showthread.php?t=209383
Alternative Oil for your Diamond Drive
http://www.snowestonline.com/forum/showthread.php?t=269361
How To
Changing the Track on Your Diamond Drive M Series
Link 1:
http://www.snowestonline.com/forum/showthread.php?t=69547&highlight=track+install
Link 2:
http://www.snowestonline.com/forum/showthread.php?t=190002
Installing Ice Scratchers on your sled
http://www.snowestonline.com/forum/showthread.php?t=233420
2010-2011 M8
M1000
Suggested Gearing
Porting
RKT M1000 Porting
M7
General M Series
Chassis/Body
Suspension
Skis for M-Series
Clutching
Engine/Exhaust
Oil Delete:
Air/Fuel
Choosing an Intake
Diamond Drive
How To
Link 1:
Link 2:
