PLEASE READ THIS ENTIRE POST.. MANY QUESTIONS ARE ANSWERED IN THIS FIRST POST OF THIS THREAD.
I've been working with Mike at Van Amburg Ent. on a new concept for tunnel sides/boards/edges/bumper for the 2007 and up RMK's.
Who would be intersted in buying this "kit" from the concept (above) that will not need to get into stripping the sled down to the bulkhead?
Would not needing to remove the tunnel/tank/track/driveshaft/chaincase make a difference to you in doing this kit compared to a full blown tunnel replacement or doing nothing at all?
Would getting most of the function and looks of a Boondocker tunnel, without the need to strip the sled to the bulkhead, make a difference on weather or not you would purchase a tunnel mod "kit" compared to purchasing a full tunnel replacement?
It is in the CONCEPT STAGE RIGHT NOW.... NO OTHER INFO ON PRICE OR AVAILABILY IS AVAILABLE.
This may not be made at all... this is simply to get an idea of who might be interested.
I do not work for VE.
The benefits are the deep snow performance of the Boondocker tunnels, a bit lighter weight, built in snow-elimination running boards, wider running boards and MUCH IMPROVED foot placement for boodocking and climbing! A better bumper to grab that doesn't get trapped by the snowflap when you are burried is a big plus too.
It would also be useful for someone with rear tunnel-side damage.
The full Boondocker tunnel is a superior tunnel to almost anything out there. Great strength, excellent deep snow function and excellent cooling performance.
It does take quite a bit of time and experience to do the job correctly though as well as having a higher price point than a tunnel side mod.
An idea of Labor to install a complete new replacement tunnel. NOT THIS CONCEPT WHICH IS OUTLINED ABOVE
Here are some concept pics of a ROUGH cardboard mock-up of a Raw tunnel that I have removed from a wrecked sled.
Tunnel removal IS NOT needed for this concept.
This would be only for the RAW Chassis RMK's from 2007 - 2009.... NO other models or brands are in the works
The concept is to strip out the suspension, bumper running board edges, Drop brackets etc...
Leave the fuel tank, drive shaft and track in place, stock tunnel sides stay on. Then, cut off the stock running boards, and part of the back of the tunnel sides off.
Rivet on the new Boondocker tunnel sides with integrated drop brackets, Rivet the running boards in place, Bolt & Rivet on the running board edges, Bolt on the rear bumper/tunnel closeoff/flap mount .. Reinstall the skid and Viola!!! You have a VE-Boondocker/RAW hibrid.
Remove Seat, Console, fuel tank, steering hoop/stirrups, lower front body work, Secondary clutch, Chaincase/gears, jackshaft, drive shaft, track, Drain the coolant from the system, remove the coolant hoses from the tunnel, Then grind-off/drill-out all the rivets that hold the tunnel on, remove the tunnel stock tunnel. Then carefully align the new tunnel, Rivet it in place, cut the holes for the driveshaft, locate the suspension holes and drill them, fab new plumbing for the new running board edge coolers and reverse the process above to re-assemble the sled. Most of this can be eliminated with the concept proposal that I'm talking about here.
