I just installed Polzinhunter's 2005 RMK Rider-Select delete in a project sled I'm working on...
TOP NOTCH QUALITY...
All stainless steel fastners, very accurately and cleanly cut aluminim, high quality bushings, and fit perfectly...
On the 2005's... I riveted a stainless t-nut on the backside of the steering hoop to be able to remove install without pulling the tank... You have to pull the tank to remove the stock Rider Select on the 2005's not the 2006's...
I would recommend this to anyone who is looking for a tighter steering post that will take a beating on rollovers and roll to un-stuck situations...
His kit has 3 different positions to lock into ... EDIT: 4-5-6 position relative to the Rider Select mechanism.
It's good to see made in the ole USA quality like this!!
Link to other info on these kits for 2005 AND 2006 RMK/Fusion/Switchbacks
http://www.snowest.com/forum/showthread.php?t=114681
