2008 Polaris Dragon 800 with Carl's Motor Mods and much more!
RMK935VA
2008 Polaris Dragon 800 with the following mods:
- 2009 163" Polaris Track
- 2009 Walker Evans Shocks (front and back)
- 2009 Polaris Spindles
- 2009 Polaris Gripper Skis
- Carls' Porting,head mods and ECU mods
- SLP Y Pipe, Pipe and Can
- TCP Front Bumper Package ($600 installed at Carl's)
- V-Force 3 Reeds
- SLP Airbox Mods
- SLP & Carl's Venting
- Carl's Clutching
- R&M Lightening Side Vent Panels
- R&M Lightening Air Intake Vents (top under the windshield and sides)
- Additional SLP Intake Vent in Instrument Panel
- Better Boards (Black Powder Coated)
- Lower Gearing Change (dropped one tooth on upper gear)
- Under Hood WPS Goggle Bag
- Bag with Shovel Pouch on Rear
- Holz Gas Can Rack
- Under Seat Bag
- Polaris 2010 Top End/ECU Warranty Repair INCLUDED!
- Polaris Idler Track Wheels (3 sets saves the wear and tear on the Hi-Fax)
- Polaris Carbon Fiber Design Windshield
This is dialed in sled with everything for the serious mountain rider. This sled was one of Jack Struther's personal rides last year. I purchased it from him directly. It has appoximately 1700 miles on the chassis. The top end will be brand new with the Polaris Warranty fix (pistons and whatever else they replace when they come out with it later this year).
I was very happy with this sled and I was going to put a Boondocker Pump Gas Turbo on this sled. However, I found a 2009 Pump Gas D8 that I am buying instead. I am swapping out the shocks (Fox Zero Pros on the 2008), track (Camoplast Challenger Extreme 2.5" on the 2008), spindles (Holz Spindles on my 2008), and skis (SLP Powder Pros on the 2008).
I have over $14,000 in this sled. I will sell it for $8,495! It is dialed and it runs very well. Call me at (208) 250-5139 or e-mail me at rmk900va@msn.com or PM me if interested. I don't have any pictures right now but I can get them if you are interested. I will deliver within 500 miles if you prefer.
I meant to say that the price is $8495 OBO. Also, the side and intake vents (on the side of the instrument panel and above it are Fire n Ice not R&M products. They make nice vents. This sled flows a lot of air to the airbox through all of the extra venting and the clutches run very cool with the side vents and Carl's vents in the front and back of the engine (both sides). Belt life has been extraordinary because of the venting and gearing change.
If the fix from Polaris includes new cylinders, is Jack going to re-port the replacement cylinders?
That is the plan although I don't think that a new monoblock is going to be part of the "fix" but who knows right now? Are you interested in the sled? I should have added that I just replaced the Hi-Fax. I replaced them at the same time that I put the idler wheels on. The sled runs very strong.
The sled is at Carl's in my trailer. I will try to get some photos of it soon. It has the red 08 Dragon hood. The vented side panels do not have any logos on them. Other than that, it looks like a standard 08 Dragon with the aforementioned bags and gas rack and the black TCP bumper. Nothing unusual under the hood to see other than the SLP airbox mod and SLP exhaust system which is ceramic coated like all of them are these days. Most of the the really good stuff is inside the motor. The 09 track and other 09 components that I am putting on it have 430 miles on them. The sled has never been wrecked or crashed. the bumper installation was done by Carl's and it does not have the hole underneath. It looks totally stock except it has the bumper that can take on trees!
do u want to trade- straight across
05 m7 ($4500) with cutler 1000cc dragon motor($4800), 450 miles on fresh rebuild($1600), 07 m1000 162" skid changes skid angle($700), no need for holtz drop brackets, 08 ported camoplast challenger only 300 miles on track($500), twin ceramic coated cutler pipes made by jaws($1400), custom diamond s titanium mesh hood($450), cutler adjustable fuel pressure regulator and gauge ($260) V- FORCE 3 REEDS($350), 2cool air vents($130), front air vents by shock towers($130) Speedwerxs high flow air intake, ($400)
3" bar riser($80), advanced timing key, new clutch($320), new stator($120), new throttle cable($70), new servo motor, rebuilt diamond drive, new seals and bearings 4-13-09, avenger digital egt's/tachometer($290), snow eliminators($120), ice scratchers($80), new attitide efi controller($400), bdx 2 wheel kit($40), 210 hp, 450 lbs. Dry, pulls like a freight train, u will not be dissapointed! Over $16,500 invested sled is located in lagrande, oregon.. Priced right at $8000
