03 RX-1 Turbo For Sale
snosfun
I am selling my 2003 RX-1 turbo.
This sled has given me 3 years of kick butt performance.
Here's the specs:
03 RX-1 with front mount MCX turbo, just replaced the header this season with a powderlites stage 2 ($1250), and also just replaced the turbo (Schwitzer) ($600). The original header was cracked and the original turbo was smoking. Now everything is back to normal. There is STM billet carb caps and billet carb T's, double divorced down pipe, straight pipe tunnel dump exhaust.
When I bought the sled it had a rear mount bender turbo with a mpi tunnel that was hashed, so I put an apex tunnel, suspension and track on. The chain case had been rolled as well but I put it back to the stock position. I put a boss seat and LED brake light on.
It also has: holz front a-arms, simmons skis, skid plate, rider forward steering post mod, 07 apex handle bars, innovate O2 sensor, boost gauge, left hand throttle, and hand guards. It has a Lincoln County Customs clutch kit with shockwave helix that works awesome.
I have been running straight AV gas and running around 10-11 psi boost at 6-10000 ft. I normally have 80-90 mph track speed while climbing. This thing is an animal. I have been told that this turbo can handle about 16 psi and I have tried it once at 14 psi when I had straight race gas in it. Holy mother did it run. The motor is stock, no shim.
I am asking $5600.
I am in Montana near Conrad.
PM, email, or call 406-788-4152
rx-1turbosmall7.JPG rx-1turbosmall6.JPG rx-1turbosmall5.JPG rx-1turbosmall4.JPG rx-1turbosmall3.JPG rx-1turbosmall2.JPG rx-1turbosmall.JPG
ttt jim! this sled is an animal!!!! someone will be getting a killer deal here!!!!!!!!!!!!!!! maby i should put mine up for sale jim! ha ha ha boost is addicting!!!
sale
you should buy my apex chassis for sale and swap everything, then you would have a climber
Mine basically is an Apex other than the plastic and fuel injection. The bulk heads are the same on both and I already put the Apex tunnel on. It already climbs like crazy, but yes it would be nice to have side panels that would come off easy like the Apex.
