IQR conversion!
Snocross 100
I was wondering if it was possible to put the body work from a IQR on a 08 700 155" cause a wrecked it and have to do new everything anyway and love the look of the IQR! I need advice, contacts of people with any parts i might need and Pics!!
Times not an issue cause I got all summer to fix it and was wondering if i could do it without swapping the bulkhead but will if i have to!
You will need to just get a rolling chassis IQR and swap your iq tunnel and track. That is gonna be the cheapest easiest way to do what you want. Doing it this way is pretty straight forward. Contact 1200 psi on here he makes tons of parts to do this.
i put iqr on my 06 900 and my wifes 05 iq 800 took about 5 hours as its fairly close had to have bill at mountain fit make me a hood to fit the cowl
went real good had to redo foot wells a little for pannel clearance. One inch raise on shock tower rivet a couple small filler pannels in front of shock tower. put my gauge in back run driving lights off bars . the bulk head was realy close. just had to buy the plastic was running a slp box on my 9 so no bumper got smashed by stuck throtle in to side of trailer so it got a notched bumper after that.
I need more help or I cant do the swap and i just got the expected cost and it is over 5 hundred dollars in parts alone and i do not want to pay that much to have a stock body!
having trouble trying to get my file size down to recamended limits bill at mountain fit will have iqr side pannels fairly soon as im running the proto types proubly about 125 a set for hdpe that should help with the cost to convert
