well, no answer. I pray this is true. I'll be the first to buy one...
08 M1000 only-yes it works like the 09-motor shuts off & runs in reverse-push button motor shuts off then go forward
don't know, have to call & ask Jeff!How come it doesn't work for the m8?
It's part of the update for the 07 and 08 1000's. There isn't a reflash for the M8. They are reflashing those sleds to the 2010 specs and the electronic reverse is already part of the program. The program changes the firing order and allows the motor to run in reverse. The stock ECU program from any 07 and 08 will not work but if you have a program for 09+ you can do it. Get some one the reflash your M8 to the 09 specs and you can do it on your M8. You just need to hook a wire from your reverse switch to the correct pin in the ECU harness and it works.
Edit, you will need to change your secondary as well as the motor will now be running backwards.
This is not a cat deal this is a Aftermarket deal. The flashing going on does not make your motor turn backwards. This is some kind of kit that he has came up with not sure have not seen it but flashing your box will not do it.
