Av gas or C12 ?
Hey
My buddy just got a 2003 800 vert escape. It has trail porting, SLP twins,
V force 3's, 155lbs comp. He was told to use 2gal C12 with 3 gal premmium
for a fuel mix and to try cutting it back from there till the Det sensor cuts in than add a little c12 and he would have a good mixture.My question is could he run straight av gas which I think is 101 or 102 actane? Or should he try the c12/prem mixture? Riding from 2500ft to 7000ft. Is C12 112 octane?
Any corrections or advice would be great.
Thanks calvin
The specific gravity of LL100 (av gas) would be less than what he has now, so he may have to jet up one size or two but he should be able to run straight av. Make sure you guys check the plugs and piston wash just to be sure your not leaning the thing down.
how much cold weather riding do you do? sleds that run straight av sometimes are hard to start in -20 temps.
155 lbs of cranking compression and trail porting on a polaris 800 should be totally fine with 3 gallons of av gas and the rest pump premium at your elevation. Check your plug color to verify jetting but 155 lbs of compression is not enough to warrant running expensive race fuel IMO
it depends on comp. guage, etc. etc. can't just go by compression number.:) doen't sound very radical, but better safe than sorry av gas is ok, you just have to use more of it. :D
Thanks
for the info guys.He is welling to run straight av gas since it is only 25cents more a litre compared to race fuel at $3 more a litre.We do ride at -20 but not to often so starting won't be a real big issue.The machine is not done up extreme, just a little extra.He just didn't want to have to run race fuel.$$$$$
We will try straight av gas and also a mix of av and preminum.
thanks guys
I believe sunoco is the only race fuel maker that makes their own fuel specific to racing. The other brands all use 100LL as the base and then add certain additives to acheive the 110-119 octane rating.
Running a little more oil will also lean out your air/fuel mixture, so pay attention to jetting. Always keep that in mind when mixing and matching your fuel/oil ratios.
SHMO
I'm not sure where you got the info to run that ratio of octane. I have a similar setup with SLP twins, trail porting, and their high comp heads and SLP told me 20% race (110 octane) is plenty. So basically 1 gallon of race in a 5 gallon jerry can topped up with premium is all they asked for. I have ran quite a few tanks through the machine and never had the deto sensor kick in and it runs great. My sled is an '04 Pro XR 800, I would think that sled should be even less of an issue if it's not running the heads. As well, if he wants to save money on race, tell him to go to the single pipe. Race mix is only required on the twins with porting, but not with the single. All this info is straight from SLP themselves and it don't hurt to call them and verify your specific application.
Sorry to hijack this thread, but I'am able to buy av gas cheap from a pilot buddy of mine. My question is how much AV gas should I run with premium fuel in the mountains ( mostly Revelstoke area )? I was guessing at least 25%, or would 50% be the way to go, as I'm running nitrous aswell. Just don't want to be detonating with various premium fuels and questionable octane #'s. Thanks for any input.
Chevron in Revy carries the 94 octane premium plus fuel as well. Tried that and my M1000 sure seem to run better on it from a seat of the pants feel. Personally, anything more than you need is a waste of money, and the DET is there and works great to let you know that your pushing your luck. The higher octan fuels to cause you to run cooler if anything and could cause performance problems if your not setup to run straight race (110 octane). I just ran 20% mix and could see a 50-75F drop in EGT's across the board on my ProXR after the porting was done with my ATACC setup taking variances outta the equation. Personally, with your setup I would run a 25% mix of 94 Chevron premium and 108/110 race gas and bring a 2.5 gal spare of race if your worried up the trail. If the DET kicks in, start dumping some of the jerry in your tank when you have room, and if you don't, run on the reg fuel setting for a while till you do. Can't be that bad if SLP told me I'm safe to come off the hill easy on the reg setting with just premium and no race gas mix at all with my twins and trail porting with the heads... The race is only required on the Polaris 800's when twins with porting are combined, and that was only 20% as well. Some info here as well:
http://www.startinglineproducts.com/technical.cfm?articleID=2
Are you including VP racing fuels in that statement? Maybe you should look into the product they offer.
Kinda long but a good read about racing fuel replacements.
How ’bout AvGas?
The only aviation gasoline of interest to Corvette enthusiasts is “low-lead 100” (AvGas LL100). Because of its antiknock rating and low price compared to leaded racing gasolines, AvGas might seem a good choice for a moderate octane boost, but closer study raises some doubt.
Because of its lead content, AvGas must not be used by engines fitted with modern emissions controls. It renders catalysts useless in short order and will eventually plug them. AvGas quickly damages most oxygen sensors, too.
The sale and use of aviation gasoline is heavily-regulated. Most aircraft fuel dealers refuse to put AvGas into anything other than an aircraft fuel tank. There is a legal gray area that has some vendors willing to dispense AvGas into approved containers if they believe the end use of that AvGas is fueling an aircraft engine. This loop-hole is how some people obtain AvGas for automotive use.
Aviation gas is formulated for large-bore, long-stroke, low rpm engines which run at high altitude. While AvGas’ higher octane is useful, smaller-bore, shorter-stroke, high-rpm, non-cat, Corvette engines requiring 92-98-oct. will perform better on racing gasoline. AvGas has lower volatility so, used in proportions higher than about 40%, part-throttle drivability and cold starts may be compromised. AvGas has a lower specific gravity so it will require a change in air-fuel ratio calibration for the engine to perform at its best. LL100 is blended with a high percentage of aromatics. That reduces throttle response–not really an issue with an aircraft engine but certainly an issue in a high-performance automotive engine.
Most small airports that cater to general aviation will sell AvGas through fueling facilities such as this. If you decide to accept the compromises of aviation gasoline, make sure what you buy is “100” or “100LL”. Do not use “Jet A”. That’s jet fuel, a form of kerosene, and burning it in an automotive engine will cause serious damage. Image: author.
The “Aviation” antiknock rating system is different than the MON rating. 100-oct. on the aviation scale, equals 98.8 MON. The biggest limitation of LL100, when used in very high-compression or high-boost, race track applications requiring leaded gas is octane. “For those applications, AvGas,” Tim Wusz told us, “is short on octane compared to most (leaded) racing gasolines. Many racing engines have more spark advance at low rpm and/or during lean, part-throttle operation than AvGas and even some (unleaded) racing gasolines can handle. The result is detonation.”
Bottom line: AvGas is ok in off-road situations were a leaded fuel of no more than 98 octane required, ultimate performance is not important and you can accept possible drivability quirks.
Blend Your Own Race Gas? Not.
If you’re a regular reader of the VetteNet mail list or visitor to the techie boards on the Corvette Action Center, you’ve heard of other do-it-yourself additives said to improve gasoline. Unfortunately, a lot of that is urban legend. The executive summary of “DIY race gas” is: mixing it can be dangerous. You sometimes loose performance. You don’t save money.
Some of these DIY additives are: aniline, benzene, toluene, xylene and propylene oxide. Forget the first two. Both are highly toxic. Aniline is absorbed through the skin and impairs your blood’s ability to carry oxygen. Handle aniline improperly and you die. Benzene is a carcinogen, so you’ll die after improperly handling it, too–it’ll just take longer. Their toxicity and that they are used in making drugs has aniline and benzene Federally-regulated and not available to the public.
The aromatic hydrocarbons (“aromatics”), toluene and xylene are octane improvers. Significant amounts of toluene and lesser amounts of xylene are already in pump and racing gasolines. Both are available from automotive paint suppliers. Both are mildly toxic. Work with them wearing chemical-resistant gloves and in a ventilated area. If there’s any question about ventilation, wear a respirator.
In California, law restricts aromatics to 35% of a gasoline blend. Elsewhere it may be as much as 40%. The effect additional toluene or xylene has on pump gas is unpredictable for two reasons: 1) the octane boosting ability of both is less effective on premium pump gases than on regular grade gas because of the aromatics premium gases already contain, 2) toluene and xylene have high octane ratings alone but may have lower octane when blended with other gasoline components and must be carefully tested when mixed with other gasoline components.
Toluene and xylene have specific gravities higher than pump gas so the more of them you add, the leaner you need to calibrate the engine’s air/fuel ratio. Once you calibrate for toluene- or xylene-spiked, DIY racing gas; don’t go back to running conventional gasoline until you recalibrate to a richer mixture or you’ll be burning pistons.
“Adding more toluene,” Tim Wusz told us, “will increase the octane numbers of the gasoline, but when you get above 45 or 50%, throttle response is poor and the flame speed is reduced to where increasing amounts of fuel are still burning as combustion gases are forced out the exhaust valve. Once that happens, power is lost, not gained.” Image: author.
Both have less volatility, so engines burning gasolines laced with high concentrations of them can be more difficult to start when cold.
In addition to handling, mixing, calibration, drivability and performance problems associated with DIY race gas, it has a lousy business model, too. A late-model Corvette with a medium-boost, aftermarket supercharger kit at the drag races on a warm day might need 97.2-oct. to keep the engine out of detonation. Toluene, used as a blending component, is 103.5-oct. To make 10-gal. of 97.2-oct., DIY race gas (1:1, 91-oct. unleaded and toluene) costs $42.80. Do it with 91 and 100 unleaded gasolines, you mix 3:7 for $32.05. Because a 1:1 mix of toluene and pump gas costs you performance and throttle response due to slow burn speed; not only is DIY race gas a lot more expensive, but it won’t perform as well, either.
The economics of xylene are worse than toluene. Xylene from industrial sources is “mixed-isomer” and has less octane boosting ability than toluene and a higher unit cost. The higher octane, single isomer varieties of xylene, typically obtained through science and laboratory supply businesses, are obscenely expensive, upwards of $100 per gallon.
Misunderstanding surrounds propylene oxide. Common uses for it are pesticide and fumigant. While the EPA lists it only as a “probable carcinogen,” ingesting propylene oxide will at least make you sick and can cause coma or death. Use care when handling it. Some racers are under the impression “P.O.” is an octane booster, but it is not. It is an oxygenate that works like nitrous oxide but not as well. “It will improve performance,” Wusz stated, “but the mixture must be richer to take advantage of that. PO is more effective than MTBE but less effective than nitrous. The downsides of PO are: 1) it attacks plastic and rubber parts in fuel systems and 2) its low, 95 deg. F boiling point gives it a tendency to easily escape from a blend leaving the DIY race gas blender with a gasoline which he thought contained a certain amount of PO, but in reality, may have retained far less of it. This makes tuning exceedingly difficult.”
Bottom line:
brewing your own race gas a foolish move for a lot of reasons. You’re better off buying it ready-made.
Racing Gas
Our dyno test showed the best gasoline choice for a computer-controlled car that sees a little detonation on hot days is a mix of racing gasoline and pump gasoline.
Image: author.
Many think racing gasoline is just for racing but, in recent years, the term has also come to mean high-octane, unleaded used by street cars. The obvious reason to use race gas is higher antiknock rating, but just as important is: it’s an optimum, balanced blend of hydrocarbons and additives intended to produce the highest possible performance from a high rpm, automotive engine. It’s better than pump gases fortified with octane boosters, better than AvGas, better than pump gases spiked with store-bought aromatics and the only alternative if you want your engine to perform best. There are 10 vendors of racing gas in the United States. Most sell through distributors, however, in a few urban areas, some refiners sell racing unleaded at retail service stations.
“Entry-level” racing gasolines are usually unleadeds of about 100-oct., R+M/2. Eight of the 10 companies sell it. Octane ratings vary from 93 to 99 MON, a significant gain over the approximately 88 MON of the best pump gas. Racing unleaded is the perfect choice if the engine in your Corvette needs a moderate octane boost. It is good for engines with superchargers of moderate boost, modest nitrous oxide injection systems or any modifications that increase cylinder pressure somewhat over stock levels.
We asked Tim Wusz about Rockett Brand 100 and he said, “This product has been used in endurance (sports car) racing in four-inch bore engines with 14:1 compression ratios and aluminum heads. With cast iron heads, compression ratio should be limited to 12:1. It can be used in current performance street cars. Historic muscle cars can also benefit from this product which easily services the 11:1 compression ratios of many engines from that era.”
The other half
When late-model Corvette is run hard on hot days, as shown in our tests on the SuperFlow Auto-Dyn with the ZR-1 and later with a Z06, engine computers will often enable spark retard. This is because the car’s engine controls are calibrated for aggressive spark advance to get best performance in cool weather, then “save” the engine with spark retard when mild detonation is sensed during high-load/hot-weather operation. Because of the retard, their performance is reduced slightly and coolant temperature is slightly higher.
On cool days there’s no problem, but in warm weather, the engine will get a little detonation, the knock sensing will retard spark and performance will drop slightly. A small amount of unleaded race gas mixed with premium pump gas (start at 1:5, then work up) is the best way to eliminate this problem, short of engine modifications, changes in calibration or moving to a cooler area.
Does this work in practice? At our shop, we drained our test Z06’s fuel tanks, added 10 gallons of Rockett Brand 100 then drove 50 miles to a session on the Auto-Dyn at Westech. The IAT was 106°F and the dyno read 9.5hp more than the first test on straight unleaded premium. After lunch, we “thinned” the remaining Rockett 100 down to 94.6-oct. by mixing it 2:3 with Chevron 91-oct. unleaded and ran again. The IAT was now 109 and the power was up 7.5hp over straight pump gas. In all runs of this second round of tests, our Vetronix Mastertech showed no detonation. Clearly, in hot weather, unleaded racing gas works well as a detonation fighter.
Some think unleaded race gas is prohibitively expensive but, for a given octane, compared to pump gas spiked with pour-in additives; its economics are usually more favorable. Don’t think you have to use racing unleaded at full strength, either. If your engine only needs 94.0 octane, mix it 1:2 with 91-oct. pump gas. It’s relatively easy to “math out” the proportions of the mix you want and some race gasoline suppliers have mixing charts, such as the ones from Rockett Brand Racing Fuel reproduced here, to make the process easier.
While it is true that your engine only needs as much octane as is necessary to keep it out of detonation, there are cases were a particular engine will run better on a high-percentage mix or straight 100 unleaded in spite of not needing additional octane. There’s no set rule on this and we suggest, once you’ve determined the ideal mix of pump gas and 100 unleaded to keep you out of detonation that you, also, run a test of straight 100 unleaded. In some cases the different components in the 100 unleaded and its slightly faster burn speed will improve performance even more.
A few of these unleadeds–Rockett Brand 100, for example–are street-legal in all 50 states. Another attractive feature of some, like the Rockett Brand 100 sold at Rebel stations in southern Nevada and at Gas City stations in the Chicago area, is the convenience of buying high-octane, street-legal gas at a service station–no searching for distributors, no hauling cans around and no storing gas in your garage. Just drive up to to the island, stick the nozzle in the tank and pump your Corvette full of 100-oct. unleaded race gas.
The bread-and-butter of the racing gasoline business is leaded fuel. It is the best choice for racing engines requiring more than 100 octane. All vendors marketing leaded race gas have several grades available.
Click Chart for Larger Image or
Download Acrobat
Some racing gasoline vendors make available charts like this to assist users in mixing unleaded racing gas with premium unleaded pump gas. Rockett Brand Racing Fuel has charts for 91-, 92- and 93-oct., too. Graphic: Rockett Brand Racing Fuel.
DOWNLOAD CHARTS - PDF Format
Blend Chart 90
Blend Chart 94
“We have four leaded race fuels:” Tim Wusz continued, “The first three are Rockett Brand 111, 114 and 118.
“111 is our highest volume racing gas. For 53-years, it was the official gasoline for NEXTEL Cup Racing and all other NASCAR series. It’s used by lots of ‘Saturday night’ racers in all types of competition using all varieties of engines.
“114 is more for bigger engines. Drag racers with big motors in SuperComp and SuperGas like it. It’s good because large engines often need more octane. It’s for medium supercharged applications, too.
“118 was originally developed for ProStock and worked well until so-called ‘fast-burn’ gasolines came along. The 118 is ideal for high-boost, supercharged applications. It’s also good in engines running a lot of nitrous oxide. The 118 has a little faster burn characteristic than the 114, but not as fast as our fast-burn gas.
“We have another fuel, ProStock+, that’s really better than the 118 for performance in certain applications but, because of different burn characteristics, it’s around 114 octane. It’s a very fast-burning gas for use in very high-rpm, normally-aspirated engines. It was developed for NHRA ProStock. Because of their high rpms, they need the faster burn speed, otherwise you open the exhaust valve and loose a lot of unburned hydrocarbons. If you increase the gasoline’s burn speed, you use that stuff, rather than flushing it out the exhaust, and the engine makes more power.”
Most of the other vendors have between 3 and 5 grades of leaded race gas and one company, VP Racing Fuels, has a mind-boggling, 14 different grades. If you are having difficulty making a decision about racing gasoline, contact the suppliers of these products for detailed information and recommendations.
The Future
The United States EPA announced in late 2000 it intends to discourage off-highway use of leaded gas. EPA is putting pressure on the general aviation community to accept unleaded AvGas and it also wants motorsports sanctioning bodies, particularly NASCAR, to adopt unleaded gasoline. You can bet, if NASCAR goes unleaded, other sanctioning organizations will follow. We asked Tim Wusz what plans racing gasoline vendors have if NASCAR goes to unleaded fuel.
“We did test work over five years ago with unleaded gasoline in Busch Grand National cars without any significant adverse effects. For current, 12:1 compression ratio engines required in NASCAR NEXTEL Cup, Busch and Truck Series, our hundred octane unleaded is adequate, but we have to convince the racers and, to do that, we need the support of the sanctioning bodies. A few years ago when compression ratios were 14:1, we tested unleaded in a Winston Cup engine that had pressure transducers in all eight cylinders. We found the 100-oct. unleaded ran with no detonation. (Ed note: this test was under wide-open throttle conditions and included no part-throttle, lean mixture operation typical of running in caution periods or of engines not calibrated properly for part-throttle operation) This engine was optimized with 34-degrees spark advance. Then, we started bumping the timing up. We got up to 42-degrees before there was any indication of detonation. Normally, two degrees is an octane number so we had a cushion of about four octane numbers.”
“At Rockett, we have the technology to make a 105-octane unleaded but right now, the demand for it just isn’t there.” Tim Wusz commented. Image: author
If there is a conversion of motorsports to unleaded gas, perhaps the first place we’ll see it is in NASCAR Winston Cup racing. The huge appeal of NASCAR would be a major factor in marketing the switch to unleaded gasolines to motorsports, however, at this point in time (late-2004) it doesn’t look like a switch will happen anytime soon. Image: author
In NASCAR and other forms of racing that put similar demands on gasolines, the change to unleaded may be more of a cultural challenge, however, unleaded gas might be a significant technical problem in other parts of the sport. It would be a tough sell in some categories of drag racing, as well as a few other motorsports that use gasoline engines with very high compression ratios, high levels of supercharger boost, big shots of nitrous, large combustion chambers or any combination of these.
“The Clean Air Act has always exempted motorsports from a mandated conversion to unleaded,” Wusz continued, “so all the EPA and other governmental entities can do is discourage the use of leaded gasolines and request a change to unleaded.” He went on to say that the November 1999 election of President George W. Bush changed the landscape as far as the EPA’s interest in seeing a conversion to unleaded racing gasolines was concerned with the threat being greatly reduced.
At this writing (early December, 2004), with Bush going back to the White House for another four years, motorsports seems pretty safe from new pressure to go unleaded, however, if in '09, after the next presidential election, the winds of change start blowing again; Rockett Brand Racing Fuel and other providers of racing gasolines will be ready with an unleaded products suitable for NASCAR and many other types of competition.
Sources:
Sources:
Rockett Brand Racing Fuels 22349 La Palma Av. #104
Yorba Linda CA 92887
800-345-0076
info@rockettbrand.com Red Line Synthetic Oil Corporation
6100 Egret Court
Benicia CA 94510
800 624 7958
www.redlineoil.com
Vetronix Corporation
2030 Alameda Padre Serra
Santa Barbara, California 93103-1716
www.vetronix.com
Westech Performance Group
Unit C,
11098 Venture Av. Mira Loma CA 91752
909-685-4767
www.westechperformance.com VP Racing Fuels, Inc.
Box 47878
San Antonio TX 78265
210 635 7744
www.vpracingfuels.com
Return to Articles Page
Copyright © 2005 Idaho Corvette Page and CV World Internet Publishing
Thank you for making the Idaho Corvette Page
one of the oldest and most popular CORVETTE sites on the Internet!
Haven't bought any 100LL yet but was told that cooking lake
airport just east of edmonton was selling it for .25 more than preminum.Going to get some on wednesday.will post specifics than.
Sparx
He got the fuel mix raito from the engine builder. Was told to start with that mixture for starters and than keep using less C12 until det kicked in. he's probally just being safe.Good starting point I guess.
