ok guys..i have read pretty much every clutching thread i could find on the 900s..but still cant decide what i need..but have narrowed the choices..
it an 05 rmk 900 166 track..
ride at 6000-8000ft
i ride trail/boondock/hillclimb rarely but would like to..
i went out last weekend and was hitting 8050rpms at 71MPH..it didnt stay at high RPM consistently, but couldnt test it on hillclmibing cause there wasnt much to climb there..
when i get my tax return, i will be sending my primary and secondary to Indydan for balance/shim but want to send him the right stuff the first time..
I HAVE SLP PIPE/CAN/REFLASH as well
I currently have:
P-85 primary with Lightning 70g weights
Team Green Spring (140/330)
TSS-98 Secondary with Red/Black Spring (140/240)
stock helix-64/40.36ER
GOING TO RUN 18/40 GEARS with ATF
3211115 Belt
here is my choices i have narrowed it down too but dont quite know what difference the spring rates will affect..
Primary-
Blue/Pink Spring (140-340)
Green/Pink Spring (160/340)
Red spring (140/320)
Black/Green (120/340)
Secondary-
Red/Pink (140/260)
Black/White (160/260)
Red/Black (140/240)
2 Derlin Washers
Helix-
66/44-42ER
66/44-46ER
64/42-46ER
Weights-
MTX 74g w/2g in outter hole
Heelclickers setup (with primary machining)
Any inputs on what i should try out..cant afford to buy more then one of each to try out?????
ride at 6000-8000ft
I currently have:
3211115 Belt
Primary-
Secondary-
Red/Pink (140/260)
Red/Black (140/240)
2 Derlin Washers
Helix-
66/44-42ER
66/44-46ER
64/42-46ER
Weights-
