C
CATCRAZY
I have been struggling with a low to mid range bog for a year and a half. I finally figured it out yesterday. The clear plastic tube that comes out of the ECU was routed wrong. I had it routed so it pointed down in the bottom of my belly pan. While riding yesterday. I was pissed off and tired of the sled so I stopped and opened the hood to check things over. My friend look at that tube and said try routing that tube a different direction. So I routed it along the main wiring harness back towards the fuel tank. Closed the hood started the sled and punched the throttle, it was like someone flipped a switch. The sled ran totally different, it ripped all day long. THE BOG IS GONE!!!!! If anyone is curious I have a Injector perfector, a "Thing" can, and a RK-Tek secondary installed. So if you have a bog check the routing of that plastic tube. Good luck.
