Sidehilling help...
The throttle is your friend. Practice and see how much easier it is to hold the sled up when you are on the throttle. Let off the throttle and the sled will dive downhill.
snowlover is right it's way easier the faster your going and also what helps me alot is to position my feet farther back on the running boards so you have more leverage on the sled the closer to the bulkhead the harder it is.
Countersteer to level the sled up and power ON.
You should be able to do it from the neutral position, but if your just learning, put both feet on the uphill side.
Approach the hill at a 45 degree angle, as you hit the bottom of the hill, counter steer to level the sled up and pin the throttle.
Once you get the hang of it you will be able to feather the throttle and draw a flatter line.
You can climb by leaning into the hill more and desend by letting the sled flatten out or even aim down hill.
practice. Just like carving, takes practice.
Think of sidehilling as an exercise in carving. Same exact technique, just the ground is angled instead of the sled.
If you have a sway bar you may want to remove it.
On the flats, practice taking it up on one ski with both feet on same side, like you're carving. Get a feel for how the handlebar movement raises or lowers your ski.
Once comfy, head toward the base of the hill going at something less than a 45 degree angle. More like a slight angle, just before you get to the base pull it up on one ski and gradually start going up the slope at a shallow angle.
Also, remember it is better to tip up toward the hill if you're going to tip because you can still save a sidehill that way but once you tip down you are toast unless you are reaaalllly good. Don't commit you're whole body to holding the sled uphill - keep as tight as possible and you can use your body/leg as a quick balance/save measure.
As said, practice makes perfect.
Thanks for all the input guys!!! It's not that I can't do it it just seems like a fight every time I do. I try some of your techniques. I guess just more practice too.:beer;:beer;:beer;
you might want to look into a bigger riser, i dont know much about the polaris setup but when i put a 3in on mine it made a world of difference...just my $.02
Like some of the guys said, really work on your carving on the flats and gentle hills. Carve all you can. This will become a really great tool for sidehilling and boonie through the trees etc.
It's all about leverage and balance. Speed may play a role in it but I found if you can do it slow you will be able to sidehill in most conditions. Don't be afraid to bury the sled practicing and if you are anything like me you may get to watch your sled tumble down the hill a time or two.
That's exactly what my thought was on the going slow and being able to do it anywhere. Cuz sometimes you can't go fast. I may look at my stance as well. I completely overlooked that.
06 RMK900, I'm 6ft, I have a 2" riser. I just feel like I'm doing something wrong.
I got hte same machine, 6ft too. If you haven't gotten rid of the swaybar yet, do it. One of the best things i've ever done to it, next to new skis and a TCP bumper. Cheap too. :) Won't ride like a tank after that; much easier to pull over.
Really just finding the balance point after that. Get out and practice practice practice. Also, keep your feet on the boards, that's where the weight counts. I find it's easier if I scoot my feet towards the tail of the sled.
6'4 240lbs never been an issue for me, but I've been riding along time.
Its like a golf swing, if I think about it I fu$k up my swing, but if I just swing everything is fine.
