I went with Dogmeats idea. Bought some black air filter type material at the hardware store to fill in the area left open on console. I actually put most of the plastic parts to shield snow out, back in and used it as a backer plate for the foam. I made 2 layers of the foam roughly 1/4" thick ea. layer. cut the foam about 8" wide and 14" long tucked in between console/shroud cut out a notch in foam for steering post, then clamped it all down with the 2 screws at front of console ahead of the sterring post. Looks stock (somewhat). I need to get pics of it. Oh, the foam material cost 90 cents and it is enough for 2 sleds. I also used blue locktight on everthing.
