K
kennyblatz
New member
well i needed my suspension done soon and a BDX axle was 40 bucks (canada) so i made my own 2 wheel axle.
1. step one remove axle from the sled.
2. cut one side of axle so total length is just under OD of rails 9 1/8 i believe.
3. drill out hole to 11/32 the shaft is hallow so it goes in pretty straight, but i did drill the size below 11/32 first.
4. tap hole with 3/8 16 NC tap = 3/8 diameter, 16 threads per inch, national corse. DO NOT MISTAKE for national pipe thread NPT
5. flip the track ajusters to the inside and reasemble using without the 2 outer wheels or black spacers
6. a larger washer will be needed for the outside
-11/32 drill bit
-3/8 16 NC tap
-saw
-drill
-2 larger washers
thought maybe someone would like to give it a go when bored or save a few bucks on a axle kit.
-11/32 drill bit
-3/8 16 NC tap
-saw
-drill
-2 larger washers
